if there isn't, it should be very easy to do.
If you want to mock up a rough idea of what you want on the screen I can have a look at doing something.
Has anyone released a pluging which, with a touch of the screen would allow lap times to be captured, stopwatch wise?
I've had a browse but can't find anything.
Thanks,
That'd be great if you could, thanks.
It's for a mate who does a fair bit of track driving at Silverstone.
I gave him a basic large readout speedo based on a clear BMV2 background. All it does is display the GPSSPD label so isn't at all sophisticated.
Wouldn't it be nice if there was a reset-able TIMER label?
Something like this below would do the trick. At top is the GPSSPD label and "mph" text.
With a button bottom right to start and stop the timer, and timer readout to the left of that.
Ok give this a go, the timer might be a bit clunky, but the end time and lap time should be fairly accurate.
bear in mind this is my first RR extension plugin, normally I just do programs that can be embedded.
Version 1 - very much a beta nae alpha
Extract zip to RoadRunner folder
run register.bat
read the instructions in RRStopWatch.txt for label and button info
Run RR
Good Luck
Enforcer
*edit known bug, it keeps counting the secs to 99 not 59![]()
Blimey, that was quick.
I'll give it a go and get back to you.![]()
Here is a little flash timer I made for my skin. Only three functions. START, STOP and RESET.
Start command is "SETFLASHVAR;TIMER;1"
Stop Command is "SETFLASHVAR;TIMER;2"
Reset Command is "SETFLASHVAR;TIMER;3"
Right Click and Save Target As
Enforcer, you sir are a genius. It works a treat.
I shall be installing it on my pals PC as soon as possible.![]()
Before you install I need to adjust the formating, as at the moment it (as I said earlier) it counts to 99 seconds not 59 before adding to the minutes.
*edit, just thought, hitting Start after a Stop shouldn't reset the counter.
Will do the corrections tonight.
Glad you like it.
Looking forward to it.
You know, it's times like this make me think of ditching CF and switching to RR myself.
The only thing that turned me away in the first place was MapMonkey, and now there are so many more Nav progs to choose from...
Ok version 1.1
Changelog
Version 1.1
corrected seconds counting to 99 rather than 59
changed start/stop so that on restart it continues counting from where it left off.
Version 1.0
the original
Unzip over the old one.
Notice, this versionis fine for countries that use a '.' as a decimal point, for european countries that use a ',' please look further in the thread for version 1.4
