Page 11 of 45 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #101
    Dec 2004
    Working great guys, thanks! The only thing I can't get working is the routing via the "MAP" button. When I click it, it does nothing. I'm using the gasnav.exe which was posted in this thread. When I switch to an older version of gasnav, it looks like it might work, but gives me an error:
    I'm using IG4 and I believe I have a reshacked version (a friend did it for me, or at least said he did) - I can see the coordinates input screen under the destination menu. Here's my skin file if that makes any difference:
    Code:
    RoadRunner Skin
    RRScreen rrgas
    /, IMG, X, Y, Width, Height, LAYER
    IMG,0,0,800,480,"gas_buttons_off.png",OFF
    IMG,0,0,800,480,"gas_buttons_on.png",ON
    /, INC, FILENAME
    INC,LSXCOLORS.txt
    /, Y,  Back Slider file path
    Y01,"vslider1\slider_*.gif"
    Y02,"vslider2\slider_*.gif"
    Y03,"slider_battery\slider_*.gif"
    Y04,"slider_signal2\slider_*.gif"
    Y05,"redslider\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,9,440,390,35,9,440,390,35,H,01,"vslider1\pointer.gif",013,"MASTER",
    S02,399,440,390,35,399,440,390,35,H,02,"vslider2\pointer.gif",013,"SONGPOS",
    S,480,4,44,20,480,4,44,20,V,03," ",015,"BATTERY_STRENGTH_PHOCO","Battery Strength"
    S,260,4,44,20,260,4,44,20,V,04," ",15,"SIGNAL_STRENGTH_PHOCO","Signal Strength"
    /, I, x, y, w, h, Code;INDICATORCODES
    I06,711,212,50,50,"rrgas_5_icon"
    I05,455,212,50,50,"rrgas_4_icon"
    I04,183,212,50,50,"rrgas_3_icon"
    I03,711,49,50,50,"rrgas_2_icon"
    I02,455,49,50,50,"rrgas_1_icon"
    I01,183,49,50,50,"rrgas_0_icon"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,0,0,203,39,"MAINBT37",@HOLDMAINBT37@
    B,315,0,156,38,"MAINBT38",@HOLDMAINBT38@
    B,580,-3,251,42,"rrgas_zipcode"
    B,155,365,158,75,"rrgas_unleaded","LOWEST"
    B,312,365,159,76,"rrgas_distance","RANGE"
    B,470,365,159,75,"rrgas_distancesort","DISTANCE"
    B01,2,90,257,117,"SETVAR;StationNum;0||GASNAV||RUN;$skinpath$gasnav.exe|0",
    B01,265,90,255,116,"SETVAR;StationNum;1||GASNAV||RUN;$skinpath$gasnav.exe|1",
    B01,527,90,253,116,"SETVAR;StationNum;2||GASNAV||RUN;$skinpath$gasnav.exe|2",
    B01,524,254,257,108,"SETVAR;StationNum;5||GASNAV||RUN;$skinpath$gasnav.exe|5",
    B01,265,254,253,108,"SETVAR;StationNum;4||GASNAV||RUN;$skinpath$gasnav.exe|4",
    B01,2,253,259,108,"SETVAR;StationNum;3||GASNAV||RUN;$skinpath$gasnav.exe|3",
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES,
    Tooltip;LABELALIGNMENT
    L,648,393,147,31,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=RELOAD","CENTER"
    L,5,393,147,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=CLOSE","CENTER"
    L09,13,8,160,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"rrgas_updated","SCROLL-LEFT"
    L,321,2,131,31,#COLGR#,#COLGG#,#COLGB#,#SIZE1#,#FONT1#,"=  ||GPSSPD","RIGHT"
    L,468,4,9,30,45,45,45,18,"Arial","=l","LEFT"
    L,310,4,9,30,45,45,45,18,"Arial","=l","LEFT"
    L,156,392,156,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=LOWEST","CENTER"
    L,318,392,147,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=RANGE","CENTER"
    L,473,392,154,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=DISTANCE","CENTER"
    L,614,14,77,22,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial:b","=ZIP CODE","LEFT"
    L,694,8,92,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"rrgas_zipcode","CENTER"
    L,718,337,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_DIESEL",
    L,458,338,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_DIESEL",
    L,199,338,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_DIESEL",
    L,719,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_DIESEL",
    L,459,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_DIESEL",
    L,637,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,377,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,118,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,639,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,378,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,118,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT"
    L,22,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,22,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,284,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,284,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,543,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,543,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER"
    L,198,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_DIESEL",
    L,718,318,58,19,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_PREMIUM",
    L,458,318,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_PREMIUM",
    L,199,318,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_PREMIUM",
    L,719,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_PREMIUM",
    L,459,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_PREMIUM",
    L,637,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT"
    L,377,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT"
    L,118,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT"
    L,639,155,77,20,255,0,0,12,"Arial","=Premium","LEFT"
    L,378,155,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT"
    L,637,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,377,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,118,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,639,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,378,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,637,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,377,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,118,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,639,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,378,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,553,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,288,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,29,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,555,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,297,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,29,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance",
    L,118,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT"
    L,118,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT"
    L,118,155,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT"
    L,198,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_PREMIUM",
    L,718,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_PLUS",
    L,458,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_PLUS",
    L,199,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_PLUS",
    L,719,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_PLUS",
    L,459,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_PLUS",
    L,198,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_PLUS",
    L,558,303,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_5_DISTANCE",
    L,293,304,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_4_DISTANCE",
    L,33,304,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_3_DISTANCE",
    L,560,139,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_2_DISTANCE",
    L,300,140,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_1_DISTANCE",
    L,30,139,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_0_DISTANCE",
    L,198,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_UNLEADED",
    L,459,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_UNLEADED",
    L,719,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_UNLEADED",
    L,199,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_UNLEADED",
    L,458,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_UNLEADED",
    L,718,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_UNLEADED",
    L,539,254,235,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_5_ADDRESS","LEFT"
    L,541,266,235,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_5_ADDRESS2","LEFT"
    L,279,254,234,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_4_ADDRESS","LEFT"
    L,281,266,234,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_4_ADDRESS2","LEFT"
    L,17,254,238,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_3_ADDRESS","LEFT"
    L,19,266,238,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_3_ADDRESS2","LEFT"
    L,536,90,237,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_2_ADDRESS","LEFT"
    L,538,102,237,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_2_ADDRESS2","LEFT"
    L,281,90,231,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_1_ADDRESS","LEFT"
    L,283,102,231,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_1_ADDRESS2","LEFT"
    L,585,211,190,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_5_NAME",
    L,329,211,183,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_4_NAME",
    L,63,211,192,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_3_NAME",
    L,586,48,189,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_2_NAME",
    L,329,48,184,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_1_NAME",
    L,64,48,188,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_0_NAME",
    L,21,90,229,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_0_ADDRESS","LEFT"
    L,23,102,229,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_0_ADDRESS2","LEFT"
    L,22,437,61,21,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"=_","LEFT"
    L,352,444,34,28,#COL8R#,#COL8G#,#COL8B#,#SIZE1#,#FONT1#,"=+","RIGHT"
    B01,629,365,175,71,"rrgas_refresh",
    B02,-1,365,156,71,"CANCEL","Cancel"
    END
    Any help would be greatly appreciated! Thanks again for all the hard work.
  2. #102
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    What does GASNAV refer to in your exectbl.ini?
    It sort of looks like the skin is trying to do two searches at the same time, and the auto-it executable doesn't allow two instances.
    I also don't know what your SETVAR;StationNum;X is for, with the newly posted GASNAV (from this post here) you don't need to set the VAR first.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #103
    Dec 2004
    Quote Originally Posted by monkeyracer View Post
    I just looked in my exectbl.ini and there's nothing in there for GASNAV
    What should my button lines look like for the gas.skin file?
  4. #104
    Aug 2007
    monkey and enforcer , thanks , that is the problem , when i change that number , working perfect now , thanks
  5. #105
    Aug 2007
    MGD , here the gas_options.skin and gas.skin
    Attached Files Attached Files
  6. #106
    Dec 2004
    Nevermind! Got it... just had to add:
    "GASNAV","GPS"
    To my exectbl.ini file - works perfectly
  7. #107
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Mikeeps2,
    You need to include the jpg's so I can see your skin.
  8. #108
    Aug 2007
    MGD , sorry my friend , i add all , see now
  9. #109
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Ok, here is your skin back. WORKING...
  10. #110
    Aug 2007
    WOWO , my friend , now working good , thanks so much
