Page 13 of 45 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #121
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1st Remove "rrgas_#_fdnavigate" from exectbl.ini
    Add buttons with the following commands to the gas.skin
    rrgas_0_fdnavigate
    rrgas_1_fdnavigate
    rrgas_2_fdnavigate
    rrgas_3_fdnavigate
    rrgas_4_fdnavigate
    rrgas_5_fdnavigate
  2. #122
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Quote Originally Posted by Enforcer View Post
    rrgas_0_fdnavigate
    rrgas_1_fdnavigate
    rrgas_2_fdnavigate
    rrgas_3_fdnavigate
    rrgas_4_fdnavigate
    rrgas_5_fdnavigate
    He's using hAv1c 2.1, which uses labels with the exec; command instead of buttons for the gas nav, so in the exectbl.ini, go to the section where the gas commands are, after each command, replace them with:
    Code:
    "GAS0","rrgas_0_fdnavigate"
    "GAS1","rrgas_1_fdnavigate"
    "GAS2","rrgas_2_fdnavigate"
    "GAS3","rrgas_3_fdnavigate"
    "GAS4","rrgas_4_fdnavigate"
    "GAS5","rrgas_5_fdnavigate"
    hope that helps
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #123
    Aug 2007
    i have a litle problem , sometimes when i push the botton refresh or other botton , general is refresh botton , the letters and numbers are duplicated , i dont know why , if any one know , thanks
    then i need close RR an open again and working fine
  4. #124
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    OK, just had a look at these.
    The first one unfortunately uses images for the prices, this is what 'broke' the original gas prices.
    so both unfortunately are not really suitable.
    Is there any way to get text from the jpg picture and use that?
  5. #125
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You would need to use OCR software.
    OPtions are
    1. try to download the jpg and use that image as an indicator. (dis : small image might not look good or be readable)
    2. try to decode the jpg filename. (dis almost impossible and time cosuming if at all possible)
    3. download image and try to OCR it. (extra software required plus extra time to ocr it)
  6. #126
    May 2007
    Lakehood, CO
    I'm having an issue with 1.4 (unreleased) and the rrgas_gps command, it just doesn't do anything. I have the GPS connected, 6-9 sats showing, and web connectivity, and I get nothing. I registered the .dll, made sure everything was good otherwise.
    @john, sonic and thunder - are you guys having this issue too?
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  7. #127
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Works as advertised for me. Not using a GPS yet with it though.
    New Age Garmin - Skin for RR
  8. #128
    May 2007
    Lakehood, CO
    Quote Originally Posted by ThunderStick View Post
    Ya, mine was working for everything but the GPS. I know E will be gone for a few days, so it may just have to wait, but if john or sonic aren't having this issue, I'd like to know what to do to fix it.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #129
    Aug 2006
    West Allis, WI
    Quote Originally Posted by monkeyracer View Post
    Not aware of a rrgas_gps command. Must have missed that release.
  10. #130
    May 2007
    Lakehood, CO
    did you check your PM's? you're on the list for it:
    Quote Originally Posted by enforcer PM
    New Button
    ...rrgas_gps - use current Lat and Lon from RoadRunner to generate Zipcode and then get prices.
    ...obviously internet connection is required and also a GPS feed to RoadRunner to test the new button.
    ...if all is well I will release this as version 1.4.
    So, can you see if the update in your PM does anything with the GPS?
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
