Page 20 of 45 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #191
    Aug 2007
    enforcer man when i dowload the version 1.41 , donwload the last in you web , but is the 1.3.0.1
    thanks mikee
  2. #192
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    1.4.1 is unreleased except to a select few beta testers. current official version is 1.3.1 (1.3.0.1)
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #193
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by MGD View Post
    I have tryed the 1.4.1 release and my slider does not work either. Here is the code.
    S,338,465,120,12,338,465,120,12,H,"slider.bmp",,12 ,"rrgas",
    Ths is with the last official release, not mitch's as there are no solid sliders in it.
    Quote Originally Posted by ThunderStick View Post
    I am using the release I recieved friday.
    /, Y, Back Slider file path
    Y04,"ProgressSlider\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,250,180,301,41,015,352,254,035,H,04,"circsaw.g if",15,"RRGAS",
    heres the code I got,
    I tried a similar code to MGD as well
    OK, this is what I have put in the BMV2 skin I am testing with
    Code:
    Y01,"slider_battery\SLIDER_*.gif"
    S01,54,211,244,27,54,211,244,27,H,01,"",015,"rrgas",""
    I have no idea if it will work with solid sliders as I have not tested that. BUT it shouldn't make any difference unless that is a general issue with solid sliders and extension plugins.
    I would suggest you test the sliders with say songpos or volume instead of rrgas to check that your code is correct (they look ok to me, although not sure why your 'touch position' is no where near your slider TS )
    Again if you put debug=true in the ini you should get a debug.txt and if your slider code is recognised you should see entries like ReturnSlider = 5461. If not chances are that the code for slider isn't right for some reason.
    RR version I just tested with is
    Modified : 13 December 2007, 19:38:14
  4. #194
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mikeeps2 View Post
    thanks mikee
    Quote Originally Posted by monkeyracer View Post
  5. #195
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Ok, I have tried everything, I think, and I just can not get it to work.... NOt sure what the problem is.
    There is no gas.ini in the beta zip you sent the direct link for, so I just used the old one. In there I put debug=true.
    When I start RR, go to gas, enter a zip, the stations update fine. Going back to the gas folder, there is no debug.txt to be found
    Also the slider is not updating with the RRGAS as the slider code.
    If I change the slider code to SONGPOS, I can see it moving, as well as click on it to change the position of the currently playing song. (I am using the *.gif code and not the progressive slider for testing)
    This is the complete Gas_Loading.skin (The pop-up with the slider while gas is loading)
    Code:
    MEDIACAR Skin
    MEDIACAR Gas_Loading Skin
    INC,DFX_Font_Color.txt
    L,8,5,583,36,255,255,255,26,"Arial","=Loading Gas Prices....","CENTER"
    S01,16,63,564,27,16,63,564,27,H,01,"",015,"RRGAS",""
    END
    My Fiero Build Thread
  6. #196
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by JohnWPB View Post
    That was deliberate, as I assumed you all already had a gas.ini and I didn't want to overwrite any settings in there.
    Now that completely baffles me, as long as debug=true is in the ini anywhere after the [General] header then a debug.txt file should be produced.
    Code:
    MEDIACAR Skin
    END
    Well the only thing you all have in common is that you have RRGAS in capitals, however in the code I tell it to lcase it so it shouldn't matter that you have it in capitals (but for laughs try it in lowercase)
    Also can you let me know what version (ie date modified) of RR you are using.
    And you are all registering the new dll aren't you [/tgt suck eggs mode]
  7. #197
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I am using G's latest release in the rr weather now fixed thread.
    Looks like I have come full circle and have caught up with the slider not working myself now! In an extension plugin I am working on, I can not get it to set the slider for the life of me! My slider is called DimSlider, and specifically set it to 35000 in the extension plugin (around the center). When I execute the command, I get the message box directly below where I am setting the variable fine, however I am showing the var contains nothing.
    Still digging into it, and will see if I come up with a solution or not....
  8. #198
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, just tried it with the 27/05/08 beta, and it doesn't work
    However it works with the 13/12/07 version
    and the 06/12/07, 4/11/07 versions
    but not the 2/11/07 version
    So I suspect there is something wrong with the extension slider interface in the 'latest' beta.
    Will now try mitchjs one (no I won't because it doesn't seem to want to run. Oh well )
  9. #199
    May 2007
    Lakehood, CO
    Quote Originally Posted by Enforcer View Post
    exact reason we need a unified official release for RR
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #200
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Im using RR version 05/08/2008
    New Age Garmin - Skin for RR
