Page 28 of 45 FirstFirst ... 181920212223242526272829303132333435363738 ... LastLast
Results 271 to 280 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #271
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. extract the zip file you downloaded to either the Road Runner folder or Road Runner\plugins.
    2. you should have a folder called RRGas, inside this there will be a register.bat file. Double click it.
    3. Download the BMV2 skin files from post #3 of this thread. Extract to the BMV2 skin folder.
    4. There should be a file called 'add to Exectbl.ini', open in notepad and copy the contents to the file Exectbl.ini in the BMV2 folder, if that file does not exist rename 'add to Exectbl.ini' to 'Exectbl.ini'
    5. edit menu.skin and add x,rrgas after the graphics file line.
    6.you will now have to create/change a button in the menu.skin to be "RRGAS"
    and that should be it.
  2. #272
    Dec 2004
    I've been having trouble with the rrgas_gps command. When I press the button that i've configured to do it, nothing happens. I can tell that the program is "trying" to do something as the scrolling time/date stamp pauses for a second or two, then continues scrolling. I've made sure my GPS signal is good. I use GPSGate w/ my Garmin USB 18, which works fine with iG. Any thoughts?
  3. #273
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Do you have an internet connection at the time?
    and are you passing the GPS signal to roadrunner?
  4. #274
    Dec 2004
    I think so - I'll have to try it again. So I'm guessing the rrgas_gps command gets the zip and tries to download the prices right away? Would the zip change w/out an internet connection?
  5. #275
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It uses the internet to get the Zipcode from the GPS coords.
    I use this method rather than the ziplocator.dll as too many people were having trouble with it.
    And seeing as the plugin is internet based to get it's info it seems reasonable to assume people have an internet connection when updating.
    Although I can see the possibility that someone doesn't have internet in their car might want to store up some locations to get the info when at home/office, save the results using the save feature and then load up when in that area.
    Maybe I need to add some code that will store the GPS coords if internet is not accessable, which can then be loaded up , zipcodes obtained and then prices obtained from that zipcode.
    Interesting. hmmm.
  6. #276
    Dec 2004
    Yeah I think I'm having an issue w/ my Blackberry and tethering... I'll see if I can get it working and try it again.
  7. #277
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I am using the BMV skin you posted here as well as the icons folder you posted and the latest RR.exe (10/13/08) and I can not get any iconsto work. Do you have a suggestion?
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  8. #278
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Make sure there is not an outdated plugin running that fouls up the icons.
    And the icon folder (Gas) should be in the root of the Road Runner one.
  9. #279
    Dec 2007
    ok,, progress bar works great.. Everything seems ok now... love the save and load feature.... awsome..
    a question, i am missing an icon for fina, do i just download an icon and name it fina, put it in the folder?
  10. #280
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by brandensin View Post
    Basically it needs to be the same name as the station name and be a gif file.
    here is one I have just done, I will add it to the zip file in the FAQ post
    nb. If anyone else has the odd station logo missing, let me know and I'll try to find a logo and add it to the zip for others (or if you can find the logo just post it here).
