Try this new GASNAV.exe. It will cancel any previous route and the n select the new one.
Printable View
ok, flame me. i know im missing something. its not working (at least for me). only have X,RRGAS on menu skin, button cmd to start (load) the gas is rrgas. I click it and nothing happens........
I just found that another plugin was interfering... The TIMEEXEC plugin that Guino did a year or so back. It is designed to fire events at certain times of the day. I turned it off, reloaded the skin and the indicators are now showing up.
http://img139.imageshack.us/img139/4056/rrgas2uf2.jpg
Thanks goes to notepad, not Enforcer....:D
Nice...just hope that this lasts as long as the old one did!
You need the plugin. ;)
Only a few beta testers have it at present, some should be fairly obvious to you, so unless one of them has slipped you a copy under the counter you won't have it yet.
I will probably release it to the masses later on today or tomorrow, with a few tweeks suggested by John, until then paitence young padwan.
When I started emabling plugins again, when I enabled the RRMedia plugin, the icons once again stopped working. Something has to be done once and for all with the plugins messing with each other. I know absolutely nothing about it unfortunately...
I know there was discussion at great length involving Guino, Sonic and Blue.... I just dont know what the final out comes was, if there was one....
Have you tried switching the order?
