Page 30 of 45 FirstFirst ... 202122232425262728293031323334353637383940 ... LastLast
Results 291 to 300 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #291
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    yeah
    http://www.ok.dk/Priser/BenzinOgOlie/Listepriser.htm
    it's in danish but i think you can figure it out but a short list to explain what is what:
    Benzin Blyfri 92 is unleaded 92 octane gas
    Benzin Blyfri 95 is unleaded 95 octane gas
    Benzin Oktan 95 is leaded 95 octane gas
    Svovlfri Diesel 10 ppm is just normal diesel
    The prices is danish kroner for each 1000 Liters
    as for stations i could ask them for a list, the webpage only allows to search for the nearest one
  2. #292
    May 2008
    I just downloaded RR gas from your site, and I am confused.
    The Readme says:
    Extract to your RoadRunner folder, you should now have a folder called RRGas.
    I downloaded the winRAR, extracted to RoadRunner folder, and I see a GAS folder, but no RR gas.
    Should I have copied the folder over - or did I extract them to the wrong place?
    I am following the Readme from the new carwings transparent, and it says to get RR Gas from your site and install it. Can you help me get it installed?
    Also Downloaded Traffic Cams and that seems to extract fine, but I have no idea how to follow the directions for either RR Gas Or Traffic Cams after the "double click register.bat".
    Are the rest of the instructions handled by the Carwings Transparent? The Readme for Carwings Transparent seem to make me think everything else is in place:
    Follow directions included with download. All skin files are already in place so once you follow authors instruction everything should work.
  3. #293
    May 2008
    Quote Originally Posted by Minoritydan View Post
    The Readme says:
    Thanks in advance for the assistance.
  4. #294
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by Enforcer View Post
    got a link?
    yep, http://www.ok.dk/Bilist/Priser/Benzi...istepriser.htm
    hope you can sort out what is what
    but i will write them for a list of all their gas stations... on the webpage you can only search for them
  5. #295
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The Readme says:
    Sorry, the version of winampZip I used to zip the last upload didn't retain the folder format, so you probably now have the RRgas contents in the root of Road Runner.
    I have uploaded a new zip which does retain the folder structure.
    I have also changed the readme
    To bring it into line with the new plugin recommendations you need to extract to the \Road Runner\Plugins\ folder. (you may have to create that folder yourself)
    I would recommend you move your RRTC folder to \Road Runner\Plugins\, run the register.bat again.
    Both RRGas and RRTC will need to have the following added to the menu.skin of the skin you are using (if that hasn't already been done by fixerofallthings)
    x,RRGas
    x,RRTrafficCam
    and you should be good to go.
  6. #296
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by boelle View Post
    yeah
    Hmmmm
    How does it determine which is the nearest one?
    Also does it give the location of the that station?
  7. #297
    May 2008
    Sorry, the version of winamp I used to zip the last upload didn't retain the folder format, so you probably now have the RRgas contents in the root of Road Runner.
    Did you just upload a new zip to your site? I just downloaded it and the readme looks the same, I want to make sure I got the right version.
    x,RRGas
    x,RRTC
    I looked at my menu.skin of the Carwings Transparent release and it has the following:
    x,RRTrafficCam
    /x,RRPetrol
    x,rrgas
    Its not the same syntax as what you said, but I think fixer took care of adding those.
  8. #298
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RRTrafficCam is correct, sorry getting mixed up.
    The new zip is up there, it should extract to a folder called RRGas now, if it does not, you are probably getting a cached version.
  9. #299
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @minoritydan, just noticed you have downloaded the standalone version of trafficams as opposed to the RoadRunner plugin.
  10. #300
    May 2008
    Sorry for posting that link, and I found it, I was in the wrong section.
