Page 34 of 45 FirstFirst ... 242526272829303132333435363738394041424344 ... LastLast
Results 331 to 340 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #331
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    I want to add a couple icons of stations in my area, the gas station name is showing but with a generic icon. How does the label know what icon to show? what should i name the new icons? just like the station's name?
    Quote Originally Posted by PontiacGA View Post
    I did the same thing. Whatever name shows up in the gas screen is what you name the picture file. IE, in my area, theres a Turkey Hill mini mart. It shows up in Gas as Turkeyhill, so I renamed the gif picture turkeyhill.gif. Now, if I could figure out how to get the Giant/martins picture to work.
    For giant/martins what you could do is stick a martins.gif icon in a subfolder in the gas folder called giant.
    If you do add any new icons, can you post them here or send them to me via email.
  2. #332
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by Enforcer View Post
    Ha ha!
    Heres the two I've made so far.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  3. #333
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Yep, worked like a charm!
    Rename the jpg to gif (not sure if that's necessary but all the other icons are gif)
  4. #334
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, I'll add them to the folder, cheers.
    as for the giant/martins thing, I'll strip the / from the name for the icons, so you can just have giantmartins.gif
    For roadrunner it can be jpg, gif, bmp or png as long as it is named .gif.
    for the standalone version it has to be a gif if named as a gif (I think)
  5. #335
  6. #336
    Mar 2006
    Pennsylvania
    Do I need to use the new converter for this to show up, or the next version of RRGas?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  7. #337
  8. #338
    Mar 2006
    Pennsylvania
    Cool. thats what I thought.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  9. #339
    Jun 2004
    Rochester
    rrgas_gps problem
    I am having a problem with RRGas deriving the zipcode from the GPS location (rrgas_gps command). I am using MatrixPC's CFX-TX skin and I'm trying to update it to use RRGas. So far everything is working perfectly except the rrgas_gps command. I've changed a button to fire this command, but it doesn't seem to do anything. It seems like it tries to do something (screen freezes for just a second), but no update.
    I've turned on debug mode in gas.ini and here is what is happening when I push the rrgas_gps button.
    1/27/2009|12:44:32 AM|UH5
    1/27/2009|12:44:34 AM|Process Command ONBTNPRESS
    1/27/2009|12:44:34 AM|Process Command rrgas_gps
    1/27/2009|12:44:34 AM|RRlat :38.08818:
    1/27/2009|12:44:34 AM|RRlon :-78.5810433333333:
    1/27/2009|12:44:34 AM|GZZip : <Url was ere>
    1/27/2009|12:44:36 AM|12|0
    1/27/2009|12:44:36 AM|Process Command ONCOMMANDINVALID
    It does appear to get my actual coordinates, but it is failing before the gas.ini file is updated with the new zipcode (I am assuming it should be updated after sending the rrgas_gps command). I'm a newbie at this skinning business and I'm not sure what I'm doing wrong. Any tips would be greatly appreciated.
    Thanks.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
  10. #340
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looking at the dubug printout it looks like it had trouble getting the endpoint of the zipcode. the line after the url shows the start position of the zipcode and then end position, in this case it seems the endposition is 0, in other words it couldn't find the string that signifies the end.
    but looking at the file the url should provide I don't see why it wouldn't.
    All I can think is the file is getting corrupted when it is being downloaded.
