I cannot seem to get the icons to load, is there a seperate icon folder that I need to add to rrgas. Its not part of the the download.
Mike
Edit: Mike says thanks, I knew I saw it somewhere that fixed it right up.
Mike
Mike
still never got the zip from gps to work, im at a loss.
Looking at your debug you posted earlier it looks like the file that was downloaded with the postal code diodn't match the format the program is expecting, therefore it couldn't extract the zipcode.
Now putting the url into a webbrowser here gives me a correct format file.
So I can only conclude that the file you are downloading is either corrupt, the website didn't like your IP Address so has sent a non available type page or your firewall may have blocked the site.
Try putting the url into a browser and see what page you get (should be an XML format)
i do get an xml page, i had already tried entering in each url into a browser to see what i got. i dont even see an xml file being downloaded to any folder in the plugin, should the plugin be downloading the file, or does it open and read it on the fly? how does the plugin access the internet to retrieve the information, from an external browser/program or just connects to http with itself?
