Page 5 of 45 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 443
Thread: RRGAS - Gas prices for the US - Status: Updated 12/01/10
  1. #41
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by MGD View Post
    Hey monkeyracer, in post number 2 is the folder with the images attached.
    Here is the new GASNAV.exe. You need to have iGuidance modifyed with the Coordinate fix.
    will this work with IG4
    New Age Garmin - Skin for RR
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, revised theory
    It looks like whichever plugin it goes through last will have the indicators working. But will kill it for every other plugins indicators.
    I'm looking at the source from 26 Oct 2007, which on deeper invetigation shouldn't be affected by this, so I can only suppose that something has been changed in the source code since then.
  3. #43
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ThunderStick View Post
    The only thing I dont like is that it displays the Gas station names in lower case, would be great if they were all uppercase.
    It has now been changed so that the first letter is capitalised, and if the name is only two characters ie BP they are both capitalised.
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Further update.
    Just went back to 26th October 07 executable and the indicators work fine in two plugins, whereas they don't in the later versions.
  5. #45
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    gasnav works with ig4 as long as you have enabled coordinates
    Live mp3Car Facebook Chat
  6. #46
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    It has to be the way the plugin is handling the Indicator code.
    Having a quick look at the way RR handles the Indicator codes with regards to extensions, it looks like the plugin has to return one of the following
    'false' - if the indicator is not processed by this plugin
    'true' - if it is and it's to be changed to true.
    path to graphic file - if it's to show a graphic.
    Now if a plugin returns anything other than 'true' or 'false' that indicator path will take on that value as it's path.
    so if a plugin has been written that doesn't have the line
    ReturnIndicator = "False" as a default for when it doesn't process it, it will mess that indicator and anyone else's indicator up.
    Also another possibility.
    If the value of IND is changed in the plugins indicator routine, that will also change the name of the indicator that RR will look for.
    Ok, revised theory
    This is what I thought that ending thoughts were on the disscution between me,sonic, and guino. My plugins have always left that line just as it says in the comment directly above the line "ReturnIndicator="false".
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #47
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Plugin Manager
    Quote Originally Posted by monkeyracer View Post
    The root of the issue is that there are some plug-ins that need to be loaded in a certain order, if you have two that need to be loaded last, only one wins. Someone want to make a plug-in manager plugin?
    Actually, Blue made a fantastic Plugin Manager for me for use in the DFX skin. It can turn on and off the plugins from within the skin, and saves the X, lines to an include file. Then all that is needed is X,PluginManager in the menu.skin.
    The only problem, and not a fault of BLue's plugin, is they are simply in alphabetical order. There is no way for it to know what plugins are friendly, not friendly, need to be at the bottom, if there are 2 fighting to be at the bottom and loaded last ect....
    My Fiero Build Thread
  8. #48
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Ok, revised theory
    Further update.
    So, what do we do to fix it?
    Are we to now assume that there will be an official release instead of all these beta's floating around?
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  9. #49
    May 2007
    Lakehood, CO
    this order works for me:
    /, X, Extension Name
    X,powermon
    X,RRStrings
    X,Mp3Art
    X,rrgas
    but... that's really just a temporary solution...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #50
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I think Guino needs to be made aware of my theory, and if it's true make the neccesary changes, however his time is mimited at the moment and there are quite a few 'quirks' at the moment.
    Going back to an older version (12th October) but then you lose the weather and any other enhancements that are more recent updates.
