Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 103
Thread: RRPetrol - Petrol prices for the UK - Status: Updated 11/04/10
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    "E" PM only 1 suggestion so far
    answer to PM.
    Quote Originally Posted by Enforcer View Post
    However you have given me and idea. I could have a parallel command petrol_fuelmenu that will load a menu skin petrolfuelmenu.skin that has 6 buttons and each button can set the variable $PETFUEL$ followed by the command petrol_newfuel
    And for range (seeing as only four are allowed) a parallel commad of say petrol_rangemenu could bring up a menu skin petrolrangemenu.skin that has four buttons, each button sets the variable $PETRANGE$ followed by the command petrol_newrange.
    i take also you will be adding some form of gps cord's so we here in poor old UK can enter the cord's to our sat nav's once we have found our station.
    i know the sat nav i use is not to bad , once i know the distance of the station i can look it up via POI. but some don't have this feature.
    Currently it can send the coords to FreeDrive (my Personal Edition).
    However I will look at other navigation programs, it just depends on how they can receive GPS coords to plot a route from.
  2. #12
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well if you can get them to be displayed , then the end user can manually input them, for now,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    From skin commands
    Labels
    petrol_#_lon - gas station GPS coordinates (Lon.)
    petrol_#_lat - gas station GPS coordinates (Lat.)
    where # is the station number.
  4. #14
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Nice One for the PM E
    I'l crack on with testing when i'm off next week!
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  5. #15
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ooop's
  6. #16
  7. #17
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    switch on comp this morning to finish skinning this, and now i have a runtime error, RRstop watch, variable blocked, now i assume its the petrol plug as if i disconnect it everything works fine, any ideas
  8. #18
  9. #19
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Error title RRstopwatch
    contents of error box are
    run time error 91
    object variable or with block variable not set
    this happens on start of rr before it finishies loading , same spot every time
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Can you email me (email address on my website at bottom) your
    petrol.ini
    stations.prv
    webdown.txt (if you have one)
    also if you put debug=true in the petrol.ini and run it again it should give you a debug.txt file
    cheers
  1. Petrol Price Plugin for UK
    By Enforcer in forum RR Plugins No Longer Supported
    Last Post: 08-09-2008, 12:24 AM
  2. Lilliput UK Prices
    By CdRsKuLL in forum LCD/Display
    Last Post: 06-24-2005, 10:40 PM
  3. Replies: 4
    Last Post: 11-08-2003, 06:44 AM
  4. UK Laptop hdd prices
    By Reaper in forum General Hardware Discussion
    Last Post: 06-24-2002, 04:40 PM
  5. HELP!! I need prices of parts in the UK to buy from the UK
    By percys in forum General Hardware Discussion
    Last Post: 10-05-1999, 04:51 PM
