Page 15 of 49 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #141
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Yes i see that. This has the old chip set v1.2, and the newer ELM327 are running around $100 for the newer v1.3 better error detecting and connecting units. It is also another $40 for premium software other than freeware included on a disk. I am just looking for something a little better than the cheapest. The Digimoto is the next generation beyond the ELM.
  2. #142
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I honestly have no clue if that digimoto interface will work with the plugin. It was designed to control an ELM. If the digimoto can be controlled the same way then it'll work fine otherwise you would be out of luck.
    In response to the speed issues i'm working on doing some interpolation of the data so it appears as if its coming in much faster to the end-user. This means smoother gauges and faster updates. I've found a code sample from another mp3car user where this was implemented so i'm thinking it shouldn't be too hard to implement his ideas into OBDMPG.
    I was also wondering if everybody was fine with the current mpg averaging, meaning a trip and an overall average. I've been trying to think of the best way to obtain useful data and thought adding something like a 5sec average might be useful. If anybody has any thoughts please let me know.
    I'm going to be kinda busy this week and the beginning of next week since its finals time for me but I should be able to make some serious progress over my christmas break and squash a lot of the existing bugs.
  3. #143
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by JohnWPB View Post
    Can you elaborate a little more on this? I have no clue how to calibrate this. if you determine you were off by say 30 miles in a tank of gas, do you enter 30 as an adjustment ect? The "1" means nothing to me right now, as I do not know a scale, or what it is linked to
    Almost forgot about this. If you take a look at the sample skin you'll see there is an adjust screen. After you let the plugin run for a tank of gas it will report how many gallons it thinks you used. You can then enter the amount you actually used and it will calculate the adjustment factor.
    This is actually only implemented via the Volumetric Efficiency number at the moment since I think the MAF calculation is fairly accurate without adjustment. So at the moment that variable in the ini is not being used.
    If you are getting inaccurate numbers using a MAF and would like to be able to adjust them let me know and i'll switch back to using the separate adjustment factor number.
  4. #144
    Dec 2004
    Miami, FL
    Hey, I was just installing the latest version of this and I was having a real hard time getting the OBD link to show up in the skins. I finally gave up and came inside to work on my real laptop and I came to realize that the folders for the skin stuff are NOT included in the .zip file for version 1.2. Might wanna throw those back in there.
    I tried the standalone downloadable sample skin on your website, but that didn't show up as a valid skin.
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  5. #145
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by maxxell View Post
    The "sample skin" is just the skin files needed to add obdmpg to the carwings skin. Its not a separate skin, you need to copy those files into an existing carwings installation for them to work.
    It's separate so those who just want the new release do not have to download the skin again when it hasn't change at all.
  6. #146
    Dec 2004
    Miami, FL
    Now I get it. Though that does make it trickier for those new to the plugin. I didn't know about the need to manually make a change in the skin until page 8 or 9 of this thread. There are a few instances where it says the necessary skins are in the same zip.
    My Ride
    My New Page
  7. #147
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Sorry about the confusion. I've added a little blurb to the first post that should hopefully make things clearer for those new to the plugin.
  8. #148
    Nov 2004
    St Louis
    I just installed your plugin this weekend and have a few comments.
    First could you change your install instructions to reference the ../Road Runner/Plugins/"PLUGIN NAME" directory for where to put the dll etc. We have been working an RR standardization project and all plugins should be subdirectories to this directory from now on. I installed yours into ../Road Runner/Plugins/OBDMPG and it works flawlessly from there. We're just trying to unclutter the root RR directory.
    Second, no matter what settings I change in the version 1.2 ini, I can't get my temps to show in degrees Fahrenheit. It always shows degrees Celsius.
    Third, is there a PID for battery voltage?
  9. #149
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    First, I can change the instructions no problem. I was not aware of an attempt to standardize the plugins directory.
    Second, currently the units only switches the MPG variables. I can add the temps no problem.
    Third, there is not a PID but it is a function of the ELM. The command "AT RV" is supposed to return battery voltage. I'm going to try to implement it but I won't be able to test it myself as I only have access to an emulator at the moment and not an actual vehicle.
    EDIT:
    All Instructions updated.
  10. #150
    Nov 2004
    St Louis
    Thanx
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
