Page 19 of 49 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #181
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    Yeah, but if I'm sitting still with the motor OFF, the avg FE keeps decreasing until it crashes with a divide by zero.
    That should not be the case. The avg FE is only computed when the RPM, MAP, and IAT values are NOT equal to 0. These all indicate a running engine, if any is zero no values are computed.
    Also, AT commands to clear or, reset if you will, the buffers in the ELM are sent during the initialization of communication.
    Which ELM interface are you using?
  2. #182
    Dec 2004
    Miami, FL
    Does anyone know what skins support this plugin? I have the Carwings V2 skin running just fine.
    When using Digital FX 4.0, I can activate the plugin, (so my obd hardware starts running), but I dont see anything in the software that actually uses it.
    Have any other skins been built to be compatible for this?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  3. #183
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by maxxell View Post
    There is nothing else that I am aware of. I had made a LSX Void skin for it when I was beginning development but stopped updating it.
  4. #184
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    New Version Released! Grab it at http://rr.johnmihalic.com
    Lots of changes in this version:
    Code:
    12-18-2008 - Ver. 1.3
    Changes:
    + Added linear interpolation for MAP, RPM, VSS, IAT, and MAF
    + Adjusted distance and fuel calculation constants
    + Increased internal clock to 1ms for higher accuracy
    + Added back km/l display option
    + Added polling of vehicle for available pids
    + Added X minute average option as obd_davgfe label
    - Removed MAF variable in ini in favor of asking vehicle which pids it supports
    Biggest differences are the interpolation, available PID polling, and the new X minute average.
    The interpolation will make results slightly slower, however accuracy is GREATLY improved. The X minute average is currently not implemented on the sample skin but the label is in place.
    Any Problems/Questions please post!
  5. #185
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    1. Copy files from "Com Files" Folder into "C:\windows\system32"
    2. Add "x, OBDMPG" to the menu.skin file of the skin that you are using
    3. Copy "OBDMPG" folder into Road Runner\Plugins\
    4. Double click "RunMe.bat" to register the .dll
    5. Edit Com Port and Vehicle Options in the "obdmpg.ini" to reflect your system and vehicle settings
    6. Then either use my provided skins or make your own, the plugin should be ready to operate!
    Is this exactly what is needed to do to make the plugin work, the problem is that I canīt seem to get OBDMPG to connect thru RR, only thru debug application.
    I have done steps 1-5 and in step 6 I copied the CarWings sample skin.
    EDIT:
    Found problem, I believed that step 2 was the labels, thats is the ones being pushed from the plugin but after reading RR documentation I found out that this x,OBDMPG is the startup of the plugin. Sorry.
  6. #186
    Constant Bitrate aperali's Avatar
    Aug 2007
    Rio de Janeiro, Brazil
    Quote Originally Posted by mezz64 View Post
    Code:
    Changes:
    Im anxious to test it but, d/l file was not found! ill try later.
    EDIT: Sorry, I was using getright. Stopped it and got to d/l.
  7. #187
    Dec 2008
    Thanks for the update. I download it.
    I will test it soon.
  8. #188
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    new version does not appear to work for me anymore. Upgraded from 1.1 and now all labels are 0 and stay that way. If i reregister 1.1 it works again. Probably has omething to do your new way of checking aviable pids
    Live mp3Car Facebook Chat
  9. #189
    Dec 2008
    I reinstalled the version 1.3 DLL file and drove 1.8 miles for test. Trip distance is almost same as my trip computer now but a little bit lower then 1.8. I will drive more and post again.
    Thanks.
  10. #190
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    Possible. I did debug it quite a bit before release though. The main reason for implementing it was increased speed. The plugin was wasting 250ms every time it sent an unavailable PID, giving slower updates.
    Does version 1.2.1 work fine for you?
    Quote Originally Posted by sunny868 View Post
    Thanks.
    Unfortunately this is about as accurate as I can get it. I'm not sure if you are pulling all PIDs (ExtraOBD=True), but if you are turning this option off should yield higher accuracy as you will be able to retrieve the speed more often.
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
