Page 2 of 46 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 459
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #11
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    take a look at this. maybe it will help.
    The road is long but we are getting there.
  2. #12
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    I would suggest that you prefix your labels with something to indicate they come from your plugin, incase someone has or will use the same label names.
    ie
    obd_ect
    obd_stft1
    obd_ltft1
    etc.
    Good idea, i'll get this fixed asap.
    Quote Originally Posted by tolisn View Post
    That was helpful. Looks like clear CEL requires mode 4, PID 00, and a 4-byte response. Should be no problem to implement. I have no way to test it however.
  3. #13
    Dec 2003
    Greece
    The link in post 1 points to zip file 0.5(previous version) and not 0.6
  4. #14
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Fixed. I'll work on getting the prefixes changed and implementing the CEL stuff today.
  5. #15
    Dec 2003
    Greece
    Any updates on this ?
  6. #16
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Link in first post is updated with the latest build. As per the suggestions the PID labels now have an obd beginning as below. The mpg labels defined in my sample skins will remain the same for the time being. Additionally the plugin now complies with the new indicator rules so it should play nice with others.
    I also took a stab at implementing the CEL reset, use button code "obd_erasecel" to give it a try.
    • PID 05 - Engine Coolant Temp - Skin "obd_ect"
    • PID 06 - Short Term Fuel % Trim Bank 1 - Skin "obd_stft1"
    • PID 07 - Long Term Fuel % Trim Bank 1 - Skin "obd_ltft1"
    • PID 08 - Short Term Fuel % Trim Bank 2 - Skin "obd_stft2"
    • PID 09 - Long Term Fuel % Trim Bank 2 - Skin "obd_ltft2"
    • PID 0A - Fuel Pressure - Skin "obd_fp"
    • PID 0B - Intake Manifold Pressure - Skin "obd_map"
    • PID 0C - Engine RPM - Skin "obd_rpm"
    • PID 0D - Vehicle Speed - Skin "obd_vss"
    • PID 0F - Intake Air Temp - Skin "obd_iat"
    • PID 10 - MAF air flow rate - Skin "obd_maf"
    • PID 11 - Throttle Position % - Skin "obd_tp"
    • PID 22 - Fuel Rail Pressure - Skin "obd_frp"
    • PID 45 - Relative Throttle Position - Skin "obd_rtp"
  7. #17
    Newbie rocsell's Avatar
    Mar 2008
    Downloaded it, but seems to be an error when trying to unzip it...
  8. #18
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by rocsell View Post
    Not sure what the problem could be. It works fine for me. It was compressed using Winrar. What are you using to extract it?
  9. #19
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Unzips fine here, using winrar.
    Have'n had a chance to test yet...
  10. #20
    Mar 2008
    Quote Originally Posted by mezz64 View Post
    I have winrar...but I'll try to download again...thx
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
