Page 21 of 49 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #201
  2. #202
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    Tested the new release on my 96 GM with Chinese ELM327. Better startup and calculations, but I'm losing the connection when I switch skins. Could you test this using two skins and switch back and forth to duplicate.
    Do you mean switch an entire skin or just switch between screens within a skin? I've never checked switching between two entirely different skins but I've experienced no problems switching between screens in a given skin using both Carwings and LSX Void.
  3. #203
    Nov 2004
    St Louis
    Quote Originally Posted by mezz64 View Post
    Switching between two entirely different skins.
  4. #204
    Nov 2004
    St Louis
    Enforcer's right but thats all the more reason for this plugin to have a reset, wait for ECU timeout, connect sequence at every startup - for those of us that use more than one skin.
  5. #205
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    It does. It performs one on start and resume using AT commands to clear the ELM for communications. Or, more specifically, it sends "ATZ" to reset the ELM, followed by "ATE0" to remove echoes, followed by "ATL0" to remove linefeeds, and finally "ATH0" to remove headers. This is done at the beginning of every connection. If any of these commands does not return the correct information the connect sequence is restarted after a wait timer is elapsed.
    These are all functions of the ELM connection class I'm using which I did not write. I've made some modifications for this plugin but have not changed any of the core communications procedures.
  6. #206
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    I today tested version 1.3.1. MAF still showing as 0. Also restarting the plugin (in other words restarting RR) won´t reset the ELM hardware and as a result I won´t get any data from the device on the second start. To be able to get any data from the device I need to take out and plug it back in.
    Here I enclosed my ini file:
    Code:
    [COMMUNICATION]
    COM=4
    [VEHICLE]
    MAF=TRUE
    LITERS=2
    VE=80
    TANK=62
    [AVERAGE]
    NUM=5
    AVG=0
    DST=0
    FUEL=0
    [OPTIONS]
    ExtraOBD=FALSE
    METRIC=TRUE
    UNITS=TRUE
    METRICFE=L100KM
    AVGTIME=1
  7. #207
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by tom_rosenback View Post
    If you get MAF as 0 with MAF=True then you do not have a MAF sensor in your vehicle. Set MAF=False so a synthetic MAF can be calculated.
    I still am not sure what to do with the reset problems as I am not experiencing them myself. I'll look into it.
  8. #208
    Oct 2006
    Finland
    I am 100% sure that I have got a MAF sensor in my car. If I remember correctly I got MAF values out of the plugin in versions earlier than 1.2 or was it 1.1.
  9. #209
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    tested the new version and it does the same as previous. connected indicator doesnt turn on.. all labels are zeroed out. Then at resume i got thes ame crash messages. They go away quick but i think i read
    1st. run-time error 8081 cannot connect to device
    2nd. run-time error 361 could not load or unload object
    again, 1.1 doesnt do this.. it runs as intended and resumes fine.
    Live mp3Car Facebook Chat
  10. #210
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    Both of these problems are very hard to troubleshoot since I cannot replicate them on either my test machine or actual carputer.
    Nothing has changed in regards to fetching the MAF value from previous versions. It just gets stored into an array now. If you receive MAP, RPM, and VSS values fine then the interpolation is working correctly. This is no reason why the MAF would not work and the others would.
    As to the resume issues I cannot replicate them no matter how hard I try. I have added a new class but only in release 1.3+ and you've had these same issues with 1.2 as well. Other than that nothing has been touched in the resume routines.
    Is there anybody else out there using the latest version with no issues?
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
