Page 23 of 46 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 459
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #221
    Nov 2004
    St Louis
    Quote Originally Posted by xpluis View Post
    tomorrow i reinstall complety my roadrunner and try again.......... any sugestions?
    o.k. Let's start from the beginning. What OBD module do you have? Have you tried the latest RR binary?
    Try this, disconnect the USB from the PC and the OBD module from the car, With the car running - Cold boot the latest RR binary, plug in the USB and wait for it to be recognized, then plug in the OBD and wait 15 seconds, now switch to the OBDMPG screen and see if it works. If this does work you may have a device/interrupt conflict, i.e., two devices trying to use the same interrupt.
  2. #222
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    What is the file that is the link betwen the odb and roadrunner? remember that the debub file of obdmpg its working, but not link with roadrunner.
    If i know what is the dll, or the file that link obdmpg with RR i can put more atention in this file.
  3. #223
    Sep 2006
    Mexico City
    obdmpg could be work with Road Runner Plugin Manager ??
  4. #224
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    at the rate he's putting out version updates i'd say wait til there's something more solid else he'd be wasting time sending me plugin data on an almost daily basis.
    i still havent tried the 9600 rate files .. i'll do that today and post results.
    EDIT.. that solved it.. 1.3.1 works fine now
    Live mp3Car Facebook Chat
  5. #225
    Woodbridge, VA
    Blog Entries
    32
    Question? do you have any functions handling hibernation/resume? now that i finally got the 9600 .dll working i'm having an intermittent issue with RR crashing at hibernation. It resumes back to the standard windows box saying the program has been closed yada yada. I wasnt having this problem with OBDMPG disabled.
  6. #226
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    I do have hibernation/resume routines to save the current data to the ini and close and reopen the connection to the elm. These have not changed for some time now though.
    To be more specific the preparation for hibernation routine write the values to the ini via an ini_write function, closes the elm connection, and sets the boolean connected variable to false.
    Then on resume from hibernation the form is unloaded and then loaded again to reinitialize the connection. The unloading and loading of the form might be causing your problem but it has been this way since day one as it was the only way I could get the plugin to start back up correctly after hibernation.
  7. #227
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    The debug exe is just an old build of the dll converted into an executable. The dll is what is communicating with RR and the elm.
    I'm holding off on any future fixes releases until I can get my latest build working on my carputer. It works fine with an emulator but I'm starting to think that is not good enough. With the holidays and everything else going on I've been pretty busy and haven't had much time to tinker.
  8. #228
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by mezz64 View Post
    i'll do some more testing in the next coming days.. but its gotta be during hibernation that the problem happens because it resumes with the windows error reporting message box.
  9. #229
    Mar 2008
    need instructions
    I use Digital fx 4.0 can somebody do a step by Step on how to implement this into it that would be very helpful to me thank you for any help anybody will give me
  10. #230
    Dec 2008
    Quote Originally Posted by aperali View Post
    well, i finished my rebuild today and tryed again. below you can see obdmpg running ok when metric=false.
    when I change it to metric=true then, it shows the division by 0 error.
    I have the same issue -- meeting 'division by zero' error while set metric=true. Is there any way to solve this?
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
