what OBD adapter are you using?
yeah =\
2006 Mazda 3 S Series
2.3L 4cyl Engine
Current Build
- Commell LV-677 Motherboard
- Intel Core 2 Duo T5500 CPU
- Dual 512MB PC5300\667MHz RAM
- Seagate 80GB SATA HDD
- M2-ATX 160W PSU
- Dynamix 8" LCD Touchscreen
- VoomPC I Mini-ITX Case (Black)
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
OBDPros USB
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
Hmm that is ELM compatible. Have you tried any other OBD software?
Fox Mulder
2004 Toyota MR2
i've tried the following programs
- EasyOBDII 2.2.0
- OBD DIAG (standard i think)
- ProScan 5.0 (i think a trial or something i'm not sure)
as far as ELM compatible, i would suppose. i'm not really sure. it didn't come with any technical information or anything... how do i find out?
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
http://www.obdpros.com/product_info.php?products_id=133
Yep it looks like it is compatible. I'm at a loss as to why it isn't working. I havent actually tried this plugin in the car yet though (got exams comming up) so I'm not sure if it will work with my adapter (I got one of those cheap ebay ones that claim to have an ELM chip, works with OBD Diag).This unit is compatible with the ELM327 chipset
Fox Mulder
2004 Toyota MR2
oops double post! *see above*
Fox Mulder
2004 Toyota MR2
well what happens is i can get to the page in Carwings for the OBDMPG menu. but i don't get any info, it's all zeroed out and the word "Connected" in the middle isn't lit up, so i'm assuming it's not connecting to the OBD scan tool?
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
On the carpc do you have any other OBD programs or plugins running at the same time?
Fox Mulder
2004 Toyota MR2
not at the time i'm running the OBDMPG plugin or even RR.
but i've noticed sometimes after i open another program and then exit, it doesn't always close the port or something cause i have to log out and back in...
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
