Page 33 of 49 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #321
    Jan 2007
    Greece
    I'm trying to find a way to test it at my home. Because now I spend more time at the car than at home lol
  2. #322
    Jan 2007
    Greece
    Ok mezz64, I've managed to make it work with the debug!!
    Now the problem is that it doesn't cooperate with RoadRunner (30/7/09 but also tried a 09/2008 version). I also installed the latest version of RideRunner but no luck there either.
    Can you explain the steps to install your plug in? (I've read the thread twice!)
    Finally, while the debug starts the ELM correctly, when running RR the ELM seems dead. No lights, no nothing. Nothing moves.
    PS1: In RRConfig, under Plugins page, it shows that the dll is registered. Sometimes it shows "obdmpg", others ",obdmpg.dll".
    PS2: In my menu.skin I've added X,obdmpg and also a label for rpm and conn.
    PS3: Using WinXP SP2, with your 1.4.1 version
  3. #323
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    The plugin is designed to work with the latest RideRunner versions. I no longer do any testing on older RoadRunner builds.
    Installation should be fairly straightforward with the new installer. After installing RideRunner run the OBDMPG installer, then navigate to the plugins folder inside RR and edit the ini. That's all there is to it, no need to add x,obdmpg to the skin file anymore.
  4. #324
    Jan 2007
    Greece
    OK I made it!!
    The trick was to use version 1.4, and not 1.4.1
    Thanks very much for your help, and for the great plugin you've made!
  5. #325
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Quote Originally Posted by mezz64 View Post
    You are right sonic, documentation is a bit lacking in some areas. My time is usually kind of limited so I focused on the skin_commands first.
    A quick overview for those who aren't sure what to do:
    1. Copy files from "Com Files" Folder into "C:\windows\system32"
    2. Add "x, OBDMPG" to the menu.skin file of the skin that you are using
    3. Copy "obdmpg.dll", "obdmpg.ini", and "RunMe.bat" into RR's main working directory
    4. Double click "RunMe.bat" to register the .dll
    5. Edit Com Port and Vehicle Options in the "obdmpg.ini" to reflect your system and vehicle settings
    6. Then either use my provided skins or make your own, the plugin should be ready to operate!
    The first step is important. Without it the Mscomm control that I use to communicate with the ELM will not work. Also, if you happen to already have VB6 installed on your computer you do not need to do step 1 since the files get added during the vb6 installation.
    Hi Thanks for the lovely plugin
    But can you pls help me as HOW do i get the GAUGES working.....
    I have followed all the steps and am able to get to the screen where it says CONNECTED.. ( in grey as i am trying on my laptop and do not have the ELM here ) but how do i go to the Gauges screen...
    Thanx
    Vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  6. #326
    Jan 2007
    Greece
    vicky_obee,
    there is a flashtest.skin inside the skin. Make a button and point it to that screen
  7. #327
    Dec 2003
    Oh Thanks for this... But there are no flash files that are displayed
    Where are these files... Couldnt find them in the OBD skin folder as well
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  8. #328
    Jan 2007
    Greece
    I found some gauges here http://rr.johnmihalic.com/download.php?id=19 but I don't know how and if they work...
  9. #329
    Dec 2003
    Thanx dude... Finally got a bit ahead
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  10. #330
    Jan 2007
    Greece
    There is also a gauge here http://www.mp3car.com/vbulletin/rr-p...ml#post1302890 but it doesn't work for me. Try it
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
