Page 34 of 49 FirstFirst ... 242526272829303132333435363738394041424344 ... LastLast
Results 331 to 340 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #331
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Thanks for alerting me to the fact that the flash files were not in the installer. I've attached them to this post for the time being until I can get the next release published.
    Attached Files Attached Files
  2. #332
    Jan 2007
    Greece
    mezz, for next version, can you enable the input of specific PIDs in the .ini file?
    I quess sth like:
    [PIDS]
    PID 87="obd_mysensor"
  3. #333
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by agiorgitis View Post
    I quess sth like:
    [PIDS]
    It likely won't make it into the next release as I'm already working my way through the testing stages, but I'll look into it for future releases.
    Is there a specific PID that you would like added?
  4. #334
    Jan 2007
    Greece
    I don't have anything in mind - I was just looking at these 2 pages and wanted to try some
    http://www.auelectronics.com/forum/i...e%3Btopic=22.0
    http://home.swipnet.se/g_gson/page9.htm
    Maybe you should try adding as many as possible if it's just a copy-paste thing...
  5. #335
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    It's easy to add others, but the more PIDs I poll for at once the slower the updates are for the data. Thats the main reason why the PIDs that aren't required for MPG can be turned off.
  6. #336
    Jan 2007
    Greece
    Oh, I see....
    Idea1:
    Maybe seperating the PIDs into several subcategories and enabling the category we want?
    Extra1=true
    Extra2=false
    Extra3=true
    Idea2: Setting each one PID either true of false, in the ini file. (I prefer this one because I can only activate the PIDs I want = fast refresh)
  7. #337
    Jan 2007
    Greece
    mezz64, what program I have to use in order to make my own custom obdmpg.dll, using your source files?
  8. #338
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Microsoft Visual Basic 6.0
    And as to the PID settings I think I might start working on a configuration exe so you won't need to edit a text file. Just open the exe and adjust the necessary settings.
  9. #339
    Jul 2006
    Brisbane, Australia
    I've been doing a bit of research on this stuff myself and have toyed with writing something myself to return the PID codes. The attached document outlines a method to query the scantool which returns a bitmap of supported PIDS. This will make sense if you refer to the PID codes on the OBDI Wiki.
    So it would be possible to support all 90 odd PID codes yet only poll for the ones supported by your vehicle. IN my instance, there is only about 20 PIDS supported. I have a few less than normal as I have a Diesel engine..
    The document comes from www.glmsoftware.com.au who has some free software to dechipher the bitmaps.
    Good luck with this.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  10. #340
    Jan 2007
    Greece
    robweb, another way is to use ScanXLELM as it has a function to poll and list the supported PIDs.
    mezz64, ok I managed to make a dll to my needs. I use only 5 PIDs and deleted all the others...!
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
