Page 36 of 49 FirstFirst ... 262728293031323334353637383940414243444546 ... LastLast
Results 351 to 360 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #351
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by sargeants View Post
    Well I'll throw in my 2cents worth here with a little bug with my setup.
    It's pretty simple really.
    When I go to fill up I usually reset my trip and mileage on the car, well since I've now got the car I decide to do that as well to see how well they match up. So I reset the FE then the Mileage(kms in my case) and then I'll get an error.
    Believe it's code 11 with message 'division by zero' then the plugin crashes and it then takes me multiple RR restarts to either get it working right, or I just go into the ini and clear the crazy long numbers.
    Everything else works great and I've incorporated it into my skin with a whole lot of data. This has happened with 1.4 and 1.4.1. Can't recall if it happened with 1.3 or not, since that was a while ago.
    Consider it added to the bug list. When I get back into the swing of things i'll take a look. In the mean time you might want to give the .dll released with the latest source a try. I cleaned up some code and added some GPS features, the bug might have gotten fixed along the way.
  2. #352
    Jun 2007
    St. Louis
    dam.... u just gave me a really good reason to play with the carputer again...
  3. #353
    Aug 2009
    Hi my name is Joe i from to italy, i have install in my bmw 320d car the carpc and i use elm interface for read the variuos sensors...I create the application with vb6 that read the more sensors....Can i read with vb6 this sensors?
    external temperature
    fuel autonomy
    medium consumption
    instantaneous consumption
    battery voltage
    liters tank
    I succeed to only read:
    speed
    rpm engine
    coolant temperature
    thank you
  4. #354
    Jan 2007
    Greece
    try setting ExtraOBD=True in the ini file
  5. #355
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by joepistone View Post
    fuel autonomy
    medium consumption
    battery voltage
    liters tank
    speed
    rpm engine
    coolant temperature
    thank you
    I don't believe that most of the ones you want to read are available in the standard mode 1 PIDs and as such can not be read by this plugin at this time. You can however receive battery voltage by querying the elm with the AT command "RV". This is not a function of the vehicle ECU but rather the ELM interface.
  6. #356
    Aug 2009
    For example:
    In order to read the RPM Engine i send with serial connection this string:
    mCom.Output = "010C" & vbCr
    For speed i send this string:
    mCom.Output = "010D" & vbCr
    For read the other sensors what tightens would have to send?
  7. #357
    Nov 2004
    St Louis
    Quote Originally Posted by mezz64 View Post
    Can you please put that into you plugin and create a label for it?????
  8. #358
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    I'll add it to the list. I'm in the process of moving at the moment so nothing is going to get done for a couple weeks at least until i get situated again.
  9. #359
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    as a little update with my issue... it seems to be okay if you reset the info while you're moving... that way when it goes to recalculate for the first time it's got values to use rather than the reset 0
    I'll give the new dll a try soon.
    I also second the voltage reading.
    How's the move going?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  10. #360
    Jun 2009
    I have somewhat good news to report, those of you with MAF and maybe even VSS issues, it's not you it's me!
    I'm working on adding some new features and while working through my testing regimen I noticed the MAF was not updating correctly, turns out I had some conditions in place that would only work when someone had a MAF, MAP, and IAT sensor in their vehicle, a very unlikely scenario.
    I'm working on the next release and hope to have it published soon, so stay tuned!
    Is this problem with the MPG calculation fixed in the latest 1.5 source?
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
