Page 37 of 49 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #361
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    The move is complete, just have a few boxes and things left to unpack.
    I'm waiting on some memory for my CarPC refresh. Once it arrives I should be able to start getting back into the swing of things and do some updated OBD development.
    Also look for some more skin examples as well, I think I'm going to switch over to eLite this time around so I'll be making some OBDMPG screens for that skin at least. I'll also have a little more computing power so I might put a little more effort in a flash gauge set since there seems to be a lot of interest in that aspect of the skin and the current offering was more or less just a proof of concept.
  2. #362
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by actionreaction View Post
    Is this problem with the MPG calculation fixed in the latest 1.5 source?
    As far as I can tell, yes. Only reason it's not yet published as a build release is I was not able to complete a full testing set and did not want to introduce any new issues.
  3. #363
    Jun 2009
    I wanted to build it, but I only have visual studio 2008, not vb6. when i open it it makes me try to convert it to a .net app. is there any chance you could throw up a quick compiled dll/exe as a beta?
  4. #364
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    If i'm not mistaken there should be a compiled .dll in the source archive. If you use it don't forget to use the new obdmpg.ini file that is also included. There are new parameters available.
  5. #365
    Jun 2009
    You know what, there is, i missed it. I'll try it out, thanks!
  6. #366
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    So I replaced the OBDMPG.dll and the ini with the 1.5 versions, in the Plugins OBDMPG folder and was no longer able to connect to the port. Is there something more that I should be doing?
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #367
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    you need to re-register (regsvr32) the dll and double check your com port settings in the ini
    I used the batch file that was in the previous release to do this, and all has been fine so far.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  8. #368
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    That worked. Thanks Sargeants
    So the program is working but none of the Resets seem to do anything. I get some negative MPG sometimes, and there are times when I am accelerating that I am getting 36 mpg, and when braking get .5 mpg which seems opposite of what it should be.
  9. #369
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Also now getting a Runtime Error. File type mismatch (I think) #13.
  10. #370
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by drewbp View Post
    Can you post how you have your obdmpg.ini configured so I can do some testing when I get a change to look at things again. I'm not sure why you would be a getting a file type mismatch off the top of my head, and I know I haven't checked any of the reset functions for a while, I might have broken something.
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
