Page 38 of 46 FirstFirst ... 28293031323334353637383940414243444546 LastLast
Results 371 to 380 of 459
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #371
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Here you go.
    [COMMUNICATION]
    COM=1
    BAUD=38400
    [VEHICLE]
    MAF=TRUE
    LITERS=3.5
    VE=80
    TANK=20
    [AVERAGE]
    NUM=13746
    AVG=222379.02002738
    DST=32.5336024985287
    FUEL=1.94518966231832
    [OPTIONS]
    GPS=TRUE
    ExtraOBD=TRUE
    METRIC=FALSE
    UNITS=FALSE
    METRICFE=KML
    AVGTIME=2
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  2. #372
    Constant Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    One thing I noticed is that if you turn GPS=false, you don't get a distance calculation anymore. with the 1.4 dll it would do this calculation.
    Reason I tried turning it off is because I park underground, and somedays it takes almost my trip to work for the GPS to acquire a proper signal after starting off. This in turn totally messed up the mileage.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mp3art, RRMedia
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    eventual carpc install
  3. #373
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I'll make sure to look into it before releasing anything else. I know when I added the GPS functions the intention was to make it easy to switch back to the old method, but something must have gotten messed up somewhere.
    I appreciate all the feedback, without it I would have a really hard time debugging things. That being said it would be great if from now on when someone has an issue they could post up how they have their ini file configured. This way I can try my best to replicate the failure scenario and hopefully fix it.
  4. #374
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    One thing I would like to request when you get back to working on this is that there be an option to turn off decimal places or not in the results. It might seem good for MPG results, but gives too many number places for gauges.
    Thanks.
  5. #375
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    I think that the 1.4.1.exe setup is corrupted !
  6. #376
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by pierrotm777 View Post
    Hmm... works fine for me. I'd recommend holding off for the moment anyway, or at least give the latest source build a try. I think there were a few issues with 1.4.1.
    I still haven't forgotten about updating things, just haven't had much free time lately.
  7. #377
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Great to see you're still here and plan on working on this Mezz64. Looking forward to any new updates you might bring our way!!!
  8. #378
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by mezz64 View Post
    I have only tested the setup on vista .
    I try the source asap
  9. #379
    Nov 2008
    hi, i know that this can be (i don't know how to explain this in english...) "a lot", but can you post somewhere the source code of your "debug exe", i will try to implement my own pids in vb6, but i will no use RR, it's possible?
    thanks!!!!!
    p.s. sorry for my english, i'm from spain... :-(
  10. #380
    Nov 2008
    solved!
    thanks!
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
