Page 41 of 49 FirstFirst ... 31323334353637383940414243444546474849 LastLast
Results 401 to 410 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #401
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Hey Mezz... just came across this on the weekend as I drove to my parents to steal their garage.
    The trip was well over 200KMs, but I was only showing about 56KMs travelled for the trip and overall. I don't recall this doing it in the past, and I don't think I changed anything on the machine/configs or what. But I know it's been off since Friday.
    I'll check it again tomorrow with a fresh image that I'm working on and see if maybe it was something on the computer that I messed up. I'll also grab the config/log files to be reviewed.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  2. #402
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by sargeants View Post
    Which version are you using? GPS on or off? There was a version somewhere in the mix that was underestimating distance by a significant amount, I thought I fixed it in the latest test releases.
    I'm still waiting on free time and weather to cooperate with me to do more testing. The weekend I had open it decided to dump 2+ ft of snow on PA and knock out my power so I was unable to test. Maybe this weekend will work out better.
  3. #403
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Thought I would post my debug log for you. I have times when everything is working well, but then the MAF reading will freeze, while the rest of the system is working, so I will get a reading of 100 mpg for 5 minutes. Sometimes it is the MAF that freezes, and other times it is the RPM etc etc. At these times, I may also get negative MPG.
    Attached Files Attached Files
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  4. #404
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by drewbp View Post
    Seems like the PID freeze is a result of an overloading of the send queue for the ELM class. Since I didn't write the communication class I didn't even know it had a limit on the queue until now, seems like it's 16 PIDs at once.
    I assume you have ExtraOBD=True and are requesting as many PIDs as possible? Any other oddities with the latest test build I should look into?
    Edit:
    Queue size was an easy fix. I've attached a new version (just rename to .dll) that should fix that issue.
  5. #405
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by mezz64 View Post
    Good luck with the snow - hasn't been much here
    Was 1.5.1 and I changed up to 1.5.2 and still showing the distance off. I'm using straight OBD readings - gps=false. Thinking - the latest thing I added was RRMedia, but can't see how that would cause a problem. Sorry I haven't gotten around to grabbing the debug/log file from the car to post.
    I do have extraobd=true, should I use the dll you just upped?
  6. #406
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Yes, please use the dll I added to my last post and let me know if you still have the freezing problem.
    I'll look into the distance calc.
  7. #407
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Hi Mezz,
    Still have the freezing problem. I have posted the Debug Log, but it doesn't seem to show any problems. I have noticed it is the MAF that freezes, not the RPM any more. I had the MAF freeze at 19, and then the VSS was reading both positive and negative speeds. Speeds were in the range of negative 175 and positive 365.
    Thanks.
  8. #408
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    You mentioned you have gps=false in your ini, yet the debug log is enabling the gps timer thinking it's set to true. I'll have to look and see what's going on there but that would explain the messed up distance calculations.
    Another thing you can try to see if it fixes freezing is turning off the extraobd option. There might be too many requests being sent at once to the ECU causing problems. Otherwise it might have something to do with the interpolation of those values, but you still shouldn't see negative numbers.
  9. #409
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Actually I believe that it is sargeants that has the gps set at false. I have had the gps set at true, that is why my debug says true. I do have extraobd set at true, I wil set that to false and see what happens. My skin is currently only showing 8 OBD settings. I dont know if that effects how many are being requested.
  10. #410
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Wow, I've been replying to this thread so hastily that I didn't even realize I was talking to both of you. My apologies.
    drewbp, Unfortunately with the way things are currently setup it will take the plugin a cycle to figure out which PIDs are available. It sends a request for all of them at once and then only repeats the request for the ones that return a value.
    I'm interested to see if turning off the extraobd fixes the freezing problem as that's one quirk that I've never encountered in my own testing.
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
