Page 43 of 49 FirstFirst ... 3334353637383940414243444546474849 LastLast
Results 421 to 430 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #421
    Newbie TheDoctor1971's Avatar
    Dec 2009
    I merely meant you use less fuel at idle than you do rolling. Under no load the engine should be more efficient at using fuel.
  2. #422
    May 2008
    Bend, OR
    Anyone use this adapter? http://www.dealextreme.com/details.dx/sku.16921
    I'd like to make sure it works before I pick it up, it's ELM 327 of course but over bluetooth. In the smallest package I've seen yet, so hopefully it won't hit my knee. Less wires is always better.
  3. #423
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by mezz64 View Post
    Wow, I've been replying to this thread so hastily that I didn't even realize I was talking to both of you. My apologies.
    drewbp, Unfortunately with the way things are currently setup it will take the plugin a cycle to figure out which PIDs are available. It sends a request for all of them at once and then only repeats the request for the ones that return a value.
    I'm interested to see if turning off the extraobd fixes the freezing problem as that's one quirk that I've never encountered in my own testing.
    So I finally had a chance yesterday to set extraobd and GPS to false. Within minutes the rpm had frozen and I was registering negative MAP readings.
    Just keeping you up to date with my testing.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  4. #424
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I did a little check today on a long drive. On my way back I decided to copy over the dll from v1.4.1 rather than the test ones, and found that it didn't fix the distance calculations for me. I'm gonna look at it a bit more to make sure I didn't mess anything else up, but it may not be a plugin issue for that. I'm using March RR - might try to go backwards if I've still got a copy of lets say Dec RR.
    - with the latest dll you posted here that didn't make a difference for me with distances. Not sure if the fix was only for gps or not.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  5. #425
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by steven765 View Post
    I'm using this (although mine is orange) in my Kia Sorento. It is working allright with this plugin.
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  6. #426
    Mar 2010
    Nice plugin! Anyone get this error message?
    Run-time error '5':
    invalid procedure call or argument
    I can't seem to get it up and running mine is set up on com 5, runs fine on vitalscan software that it came with.
  7. #427
  8. #428
    Mar 2010
    I'm actually in US...i don't think it's the regional settings unfortunately. =/
    if it's of any help i use the elm327 bluetooth pictured above.
  9. #429
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I wish I had a quick fix for you, but unfortunately I've been a little removed from this project for a while. It needs a good overview of the connections and calls to the OBD interface and some error handling built-in. I started working on that a while ago, but ended up getting sidetracked by other things.
    I've cleared the password requirement for the test builds so anyone can give them a shot. They may fix your problem.
  10. #430
    May 2008
    Bend, OR
    Damn I just ordered that bluetooth connector hoping it would work.
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
