Page 48 of 49 FirstFirst ... 383940414243444546474849 LastLast
Results 471 to 480 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #471
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I have no idea how well the plugin will work on Vista or W7. Back when I was actively developing it all my testing was done on an XP machine. That being said, as long as the necessary dependencies are registered for com communications I see no reason why it wouldn't function.
    As to a VB.NET version, significant changes will need to happen to the control class to work with .NET com port components versus the old school mscomm used in VB6.
  2. #472
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by mezz64 View Post
    In fact, in VB.NET the plugin is very light
  3. #473
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Glad to hear it. If you do update this to .NET and the latest RR standards, please share with the community either in this thread or start your own. I'd love to see this project continue on I just haven't had the time in recent years.
  4. #474
    May 2008
    Bordeaux, France
    I don't have an OBD interface ,so i don't know if my .NET version run well !
  5. #475
    May 2008
    Bordeaux, France
    Try please this .NET version and if it's OK i shall create a new thread !
    Attached Files Attached Files
  6. #476
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I have a program I used to use for debugging that emulates an ELM OBD interface. You can use it in combination with a virtual com port program (like com0com) to test without actually having an OBD interface. I've attached the emulator to this post if you want to give it a try.
  7. #477
    May 2012
    Melbourne, Australia
    Hi all,
    Has anyone had this issue when coming out of hibernation? It is a windows dialogue box that occasionally appears when Windows 7 resumes from hibernation.
    "Run-time error '8018':
    Operation valid only when the port is open
    I have tried searching through this thread, but no luck.
    Cheers,
    James
  8. #478
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by jlitjens View Post
    Hi all,
    Cheers,
    James
    I've seen that a few times before. Relaunching RR gets the plugin working again.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  9. #479
    May 2008
    Bordeaux, France
    Ok,
    I have worked on my .NET version and now i have a plugin that run well. The framework 3.5 is needed !
    I don't have an OBD interface, so i use this very cool simulator OBDSim.
    This thread explain how to use it !
    http://www.mp3car.com/obdsim/144136-...n-windows.html
  10. #480
    May 2008
    Bordeaux, France
    How can i convert this VB6 line in VB.NET please:
    Dim MAP(0 To 10, 1 To 2) As Double
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 11:25 AM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 05:59 PM
