Page 49 of 49 FirstFirst ... 3940414243444546474849
Results 481 to 485 of 485
Like Tree2Likes
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #481
    Oct 2010
    Ivry-Sur-Seine (France)
    If I remember correctly, the tables re-indexing is impossible in VB NET. Tables mandatory now start at 0 and loops using the index.
    dim MAP(11,1) as Double
  2. #482
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by shaken94 View Post
    In fact,
    i have modified this ligne:
    Dim MAP(0 To 10, 1 To 2) As Double
    by
    Dim MAP(0 To 10, 0 To 1) As Double
    Thanks for your help !
  3. #483
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    pierrotm777, I just tried your files, the stand alone OBDXR works just fine, but the plugin don't show any information on the screen...
    Looks like it's working, cause whe you click twice on the connect button happens the same when you click twice on the OBDXR connect button (lots of errors)... however, can't manage to get any information on the skin or rr labels as wel... Do you have any update on this plugin?
    By the way, sorry for the long time away... I am back! :P
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  4. #484
    May 2008
    Bordeaux, France
    marteline, your Inbox message is full , please can you erase some messages ?
  5. #485
    Sep 2012
    Germany - Munich
    i hope the plugin works with this stick www.ebay.de/itm/400400034435 in my BMW.
    Then i will create some flash analog indicators by using the variables.
  1. Is there a OBDII BMV2 RR plugin?
    By Dave One in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
