Page 5 of 46 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 459
Thread: OBDMPG - MPG OBDII Plugin for RR 6-12-09
  1. #41
    Nov 2005
    Missouri
    yes, it is showing zeros when the vechicle is moving.
    I also modified my own skin to display the values, including vechicle speed and coolant temp, those values are also zeros.
    ...Paul
  2. #42
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by pshadwick View Post
    ...Paul
    Post up what your obdmpg.ini file looks like.
  3. #43
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Updated release is linked in the first post.
    • PID's 04 and 46 have been added
    • All skin functions are listed in skin_commands.txt file
    • INI documentation file included in the zip
    • Added Metric option to show values in km and liters
    I'm still working on the error logging. In the mean time "obdconn" is a connection indicator. You should be able to use it to ensure the plugin is actually connected to the interface successfully.
  4. #44
    Nov 2005
    Missouri
    Quote Originally Posted by mezz64 View Post
    This is what it currently looks like. I'll add the indicator to the skin and test it in the morning.
    ...Paul
    [COMMUNICATION]
    COM=2
    [VEHICLE]
    MAF=FALSE
    ExtraOBD=TRUE
    LITERS=4.8
    VE=75
    TANK=25.0
    [AVERAGE]
    NUM=1
    AVG=0
    DST=0
    GAL=0
    ADJ=1
  5. #45
    Nov 2005
    Missouri
    OK I installed the new release and added the connection indicator to my skin.
    I now no longer even get the zeros in the milage fileds, they still appear in the vss and coolant fields, otherwise everything is just blank including the connection indicator.
    I tried it with both the LSX Void skin and my own.
    ...Paul
  6. #46
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    ...Paul
    I look over the code to make sure I didn't mess something up when I added the English/Metric option.
    The connection indicator should be working correctly in any case though, so if that's false then the plugin is unable to connect to your interface.
    Did you run the RunMe.bat file again to register the new dll? Also, are you using XP or Vista?
  7. #47
    Nov 2005
    Missouri
    I did reregister the dllI'm running XP.
    I'll play around with it some more, maybe I missed something.
    ...Paul
  8. #48
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I looked over the code again and didn't see anything obvious. I don't have access to my vehicle while I'm away at school so I have no way of testing these new builds myself.
    Try using the first build I posted here, it was the last one that I actually tested myself. It only has MPG and distance functionality but it should help determine if you can successfully connect to the plugin or not.
    http://www.johnmihalic.com/obdmpg/OBD_MPG_0.5.zip
    If that still doesn't work I'm going to make a standalone app using the plugin code that outputs all variables as it runs, should help to give you lots of feedback. The error reporting in the plugin was starting to make things too bloated.
  9. #49
    Nov 2005
    Missouri
    I installed the .5 version, still no data although I am back to zero's rather than nothing.
    I also double checked and my inteface is elm.
    ...Paul
  10. #50
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Looks like its time for the debug executable then. I'll try to get something up in the next couple of days.
  1. Is there a OBDII BMV2 RR plugin?
    By Davefocus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-02-2009, 12:25 PM
  2. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. OBDII plugin (KL/KKL) ?
    By SyNTaXer in forum CF Plugins
    Last Post: 07-28-2006, 06:59 PM
