Page 11 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 101 to 110 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #101
    Newbie flyswatta's Avatar
    Mar 2008
    The Colony, TX
    Awesome App - this makes my daily commute much better! There are some more Dallas cams that aren't in the database at: daltrans.org (shorter URL than the dfwtraffic.dot.state.tx.us). Anyway, is that enough info or do you want me to harvest the data and send you the info? Do you want the specific cameras?
    They also have a KML file if that helps (it has the coordinates in there), http://dfwtraffic.dot.state.tx.us/Da...ttachment=true
    Also, I can't figure out how to get the map working but I saw your post about the MapOff command in the ini file, so I'll check that out after work and see if it's set.
    Once again, great job!
  2. #102
  3. #103
    Mar 2008
    The Colony, TX
    Thanks for adding them to the update - saved me about 30 minutes of stop and go traffic as I was able to identify and bypass some major congestion - (ie: speedtrap) which backed up rush hour traffic.
    I still wasn't able to get the GPS part working. It keeps giving me Houston maps. Also, if you need someone to log GPS coordinates while driving, send me the logging utility you referenced earlier.
  4. #104
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I recently came back this plugin as I have been trying to setup "others". Only one of the Philadelphia Cams works anymore. The other from "penndot" are decommissioned as i under stand. How would i get the newer philly cameras for the plugin??
  5. #105
  6. #106
    Nov 2007
    PA
    Quote Originally Posted by Enforcer View Post
    I'll take a look sometime next week.
    Take yer time, thank you very much.!
  7. #107
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    Ok, just did a check on this and it looks like the Pittsburgh PA ones are the ones mainly missing. Although I think some are duplicated later on in the database.
    Mosty of the other PA ones should be working.
    Am currently getting the new URL's for the pittsburgh ones, there are some that are no longer there, but there will also be some new ones and I should be able to get the GPS coords.
    These will be added in the next US DB update.
  8. #108
    Nov 2007
    PA
    Hmm...When I search "philadelphia" only one of all that show up actually works FOR ME..."Airport I-95" cam...the others are black...Thanks for checking into it, as I truly hope its my something on my end.
  9. #109
    Mar 2008
    The Colony, TX
    I'm having a weird problem where the displays are coming across fragmented and are unviewable in the Dallas area for the I-35E cams (not sure what other ones may be affected) - it almost looks like the pictures are scrambled.
    I deleted the database and then re-loaded it, but the problem persists.
    I went to the website (daltrans.org) and they are working on on there. Any ideas?
  10. #110
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I'll have a look at those as well.
    Quote Originally Posted by flyswatta View Post
    Is seems they have a series of 12 pictures one after the other in the same image.
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
