Page 14 of 19 FirstFirst ... 45678910111213141516171819 LastLast
Results 131 to 140 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #131
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    For me, No problem if i change my language settings here also .
    Com port gps is now found BUT i think that it don't run or i don't know to use this option
    Is it possible to stay in my french language setting in an other version ? (for Carburant also if possible also ?)
    Thanks again, very good job
  2. #132
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RRTrafficcam doesn't have the GPS option yet (except for beta I sent to a couple of skinners, although I have added some more things in it since then).
    Only the standalone beta has it.
  3. #133
    Aug 2007
    Love your work. I hope to incorporate this into my carpc build soon!
    I found an xml list of all Tennessee cameras (335 in total).
    Would you need me to parse this any further?
    Example:
    Code:
      <entry>
        <title>CAMERA</title>
        <link>http://www.tdot.state.tn.us/cctv/cctvnash/cam87.asp</link>
        <id>urn:uuid:3E9DD334-B6F6-4cfb-86F9-C6E5C7ED2663</id>
        <summary>I-24 w/o Bell Rd</summary>
        <marker>36.052133 -86.670089</marker>
        <offsetmarker>36.052133 -86.670089</offsetmarker>
        <imageurl>http://www.tdot.state.tn.us/cctv/cctvnash/live/Cam87_21.jpg</imageurl>
      </entry>
    xml file can be found here: http://ww2.tdot.state.tn.us/tsw/GeoR...meraGeorss.xml
  4. #134
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ahave View Post
    Example:
    Code:
      <entry>
      </entry>
    No, that should fine.
    thanks.
    XML files are good, most states/sites that use googlemaps to display where the cameras are will have an XML with the list hidden somewhere. Hidden being the operative word in some cases. However some use SQL databases which I can't get access to, so with them it has be done the manual way.
  5. #135
    Aug 2007
    You are more than welcome!
    I tried looking for a few other states that have their cameras listed... but to little avail. After hours of poking around at the obfuscated code from North Carolina's site i found that they are using http://inrix.com/ for their information (pulling from a database i presume) and gave up.
    Many other states didn't even have the map interface, just a list of camera feeds which doesn't help us without the lat/long coords. Meh, oh well. I will keep poking around to see if I can find more.
  6. #136
    May 2009
    Enforcer: Thank you so much for making this plugin. I got it working today, and as a driver in NYC it is AWESOME! Now I can check out whats going on at the tunnels and bridges and plan my route accordingly. I also installed the gas plugin and was super impressed. I used it today to find and compare prices before filling up.
    So I'm not a total mooch, I went back to your site and clicked every ad I found.
    Once again, thanks for the great plugins, and I hope you continue your projects.
  7. #137
  8. #138
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I know it took long but I have labeled several Philadelphia area Cams as best I could. Here is a text file with them.
    Traffic Cameras in philly.txt
    Also here is a map of the Philadelphia area cams, but when I pull the map up in RR traffic cams none of the cameras are there.
  9. #139
  10. #140
    Nov 2007
    PA
    Quote Originally Posted by Enforcer View Post
    There are some PA District 11 cameras getting coords in the next DB update.
    I'll add those descriptions as well. Cheers
    Cool, thanks a lot!
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
