Page 15 of 19 FirstFirst ... 5678910111213141516171819 LastLast
Results 141 to 150 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #141
  2. #142
  3. #143
    Jul 2007
    Hi,
    I just cannot get traffic cams to work with Riderunner and DigitalFx 4.0 skin. It keeps me sending that "if ... don't appear, you need to install internal traffic cams plugin".
    Have few basic questions :
    - how much time does it take to start ?
    - where can one get databases (only UK is attached to release) - for example for Slovenia ? It's mentioned in country codes...
    - I'm really confused on different between Traffic International, RRTraffic , etc.... which one is right ?
    Thanks in advance,
    regards,
    Bulek.
  4. #144
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The current DFX is designed to use the Standalone Trafficcams (Trafficcams International), although I don't think John released the actual skin files he did for it.
    RRTrafficcam is the one to use with RoadRunner/RideRunner, but you will either have to download the BMV2 or iDrive skin files and use them with DFX or design some DFX skins yourself.
    How to setup RRTrafficcam in any skin is in the readme.txt
    Once you have RRTrafficcam running you can select other databases from a list and they will download automatically (may take a few minutes).
  5. #145
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by Enforcer View Post
    Enforcer...
    Will there be an update soon for US database (I saw other locations unless I missed it) specifically the DFW cams? The cams are still showing scrambled for DFW.
    Thanks for your help....
    Gee
  6. #146
  7. #147
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Brazilian database updated
    Rio De Janeiro
    There is however a Jennifer Lopez, the images take a while to load, this is down to the website, so may hang the plugin and as a result RR.
  8. #148
    Jun 2002
    Virginia
    Add to ExecTBL.ini?
    Enforcer,
    The read me file says there are some lines to add to the ExecTBL.ini file and refers to a file named "add to ExecTBL.ini" which I do not see in the download anywhere. Is that part of the setup now obsolete?
  9. #149
  10. #150
    Jun 2002
    Virginia
    That's now obsolete. Sorry should have removed that from the readme.
    Thanks, E.
    By the way, I tried to find some ads to click on your website but couldn't find any. Where are they?
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
