Page 16 of 19 FirstFirst ... 678910111213141516171819 LastLast
Results 151 to 160 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #151
  2. #152
    Jun 2002
    Virginia
    Quote Originally Posted by Enforcer View Post
    They're down the side on the main site not the forum.
    www.en4cer.co.uk
    Cheers
    Clickety Clickety Click.
  3. #153
  4. #154
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Problem w/Dallas,TX Cameras Scrabbled
    Enforcer,
    I am checking back to see if you will be updating the US database soon. There is a problem with the Dallas, TX cameras like before. All of the cameras are scrabbled...I checked through each one and none of them show correctly. Can you please fix these cameras?
    I appreciate your help....
    Gee
  5. #155
  6. #156
    Jan 2007
    DFW Area
    Ok....I see it.
    I appreciate your response.
    Gee
  7. #157
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Enforcer,
    I've taken it upon myself to attempt to fix the DFX5 traffic cams skin.
    I have all of the text resized to fit properly, but I've hit a couple of spots I could use help with.
    First off, on the labels and indicators are they case sensitive? (This is probably a general RR thing I should know)
    Also, it seems that when you select a cam (or change one) the cam displayed wont change until you actually exit RR and restart.
    One more thing - pressing favorite/main button seems to have no affect. I see in release notes it says "not in this version"
    Dave
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  8. #158
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Labels should not be case sensitive.
    You shouldn't need to exit RR and restart for the cameras to change.
    The current version for download is 1.3 which didn't have the favourites button.
    I let a few people (including John) have a 1.4 beta back in september but didn't get much in the way of feedback, so it got put on the backburner.
    I'll PM you the link so you can try that one. It isn't the most up to date as I have made some changes since then but it will give you a better idea.
  9. #159
    Newbie flowidc's Avatar
    Oct 2007
    MIA
    Enforcer, the cameras in Miami, Fl have all changed url's. Here is an updated excel with all the cameras in Miami with the correct urls. Thanks.
    Attached Files Attached Files
  10. #160
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    :Cool:
    Should be back working on traffic cams from tomorrow'ish now that the updated iDrive skins are out (well the Two nights red & green I have just to finish the manuals)
    I did have updated links for the miami ones but they had a direct ip address, so hopefully these will be better.
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 10:48 AM
