Page 18 of 19 FirstFirst ... 8910111213141516171819 LastLast
Results 171 to 180 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #171
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Thumbs up
    Thank you, that did the trick. RRTC Looks very polished in DFX and very usable for me now. Excellent job on this plug!
  2. #172
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Runtime Error 11 in DFX 5
    Enforcer,
    After a few minutes (~5 min or so), I get a "Runtime errror 11...Division by zero" when using the RRTC (v.1.4) in DFX5. I was using v.127 fine in DFX 4. I got it to work once in DFX5 but now it keeps giving that error code. I can go to the first screen in trafficcam but I can't do any other funtions.
    I re-ran the register.bat file but it keeps giving that error. Any suggestions?
    Thanks for your help....
    Gee
  3. #173
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by navputer View Post
    Enforcer,
    Right, this is where I start to sound like mitchjs.
    1. have you tried it with a different skin. (I doubt it will make any difference but hey)
    2. put debug=true into the traffic.ini (might need to do it in the Documents & Settings path) and then email the debug.txt to the email address at the bottom of my website (Contact Web admin). DO NOT post the debug.txt here.
    3. Try 1.3 (or 1.27) in DFX5
    The main difference in 1.4 to previous versions is the byGPS feature, so it's possible it's diving by zero to get distance. Is RR getting a gps feed?
    And 5 minutes is the default period set for doing a new check on your position against cameras positions.
    However I have just checked all the division calculations in the various modules and there is none (ncluding in the distance calculation) where it is possible to have a division by zero.
    So it's weird that you are getting a division by zero
  4. #174
    Jan 2007
    DFW Area
    Quote Originally Posted by Enforcer View Post
    Ok...I tried this again and it worked in DFX5. So, I closed RR and used the same version in DFX4 and it worked. I logged out of RR one more time, went back into DFX 5, waited a few and it gave the error again. So, it's hit and miss on the error.
    Yes, RR is getting a GPS feed. I am using gpsgate to split my comport as well.
    I sent you the debug file. I now will try an old version in DFX5.
    Gee
  5. #175
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Where did you send it to?
    If the email at the bottom of my webpage did you remove the extra '@'?
  6. #176
    Jan 2007
    DFW Area
    I think I see the issue. I am mixing both versions together 1.4 and 1.3. In DFX 5, the button points to a .exe file in rrpath\plugins\trafficcam like in DFX4 but v.1.4 (RRTC folder) the file is now .dll. The button is only "rrtc".
    I am not sure if this is causing the issue but I am trying to set it up this way now.
    Gee
  7. #177
    Jan 2007
    DFW Area
    Oh...I didn't remove the extra "@". Let me send it again.
    Gee
  8. #178
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yeah there is some confusion in the DFX skins as far as RRTC is concerned.
    And according to the debug file you are using version 1.30 not 1.40.
    It looks like there is an issue when it tries to check for a new version of the database file.
    But it shouldn't come up with a divide by zero error, I would expect a file not found or file exists error.
  9. #179
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @ Navputer
    Looks like RAWPWR was having the same issue
    I have posted what may be a later version of the 1.3x DLL in the DFX5 thread, try this out and see if it works any better.
    http://www.mp3car.com/vbulletin/rr-r...ml#post1420382
  10. #180
    Jan 2007
    DFW Area
    @ Navputer
    Yeah....I was just reading his post about the issue. I will try this version and let you know.
    Gee
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 10:48 AM
