Page 19 of 19 FirstFirst ... 910111213141516171819
Results 181 to 187 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #181
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Enforcer, I figured that I should go here to the RRTrafficCam thread and not the DFX thread and instead of jumping all around. Well I tested the dll file and then I received this popup-----> Run-Time error'9': Subscript out of range. And also at start up it doesn't get passed the "Loading RRMedia 6/6" of DFX splash screen if that helps. The only way I can successfully start up RR/DFX is to take it out of RR's plugin folder. I'm so confused on this one.
  2. #182
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RAWPWR View Post
    I knew there was a reason I didn't update the release to this version.
    Delete it, replace it with the 1.30 version.
    Then delete your database and archive folders (copy the contents of the database folder somewhere else to be safe).
    I should have a new version available in the next couple of weeks, with the long awaited cameras by GPS location.
  3. #183
    May 2007
    Cool, then I'll just wait for the next release and not complicate things. Thanks buddy.
  4. #184
    May 2007
    Hi Enforcer, any good news on the TrafficCam update?
  5. #185
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Getting there, should have a beta out soon.
    Just finishing off a manual and some bits and pieces.
    And testing it installs correctly on a clean XP and RR install
  6. #186
    May 2007
    Great!, I'm glad to see that it's going well with the plug-in. Thanks again E.
  7. #187
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
