Page 2 of 19 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #11
    Feb 2008
    Hi,
    Whjen I try to run trafficcams.exe in the skin, I get "Run-time error '53' file not found?
  2. #12
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmmmm trafficcams.exe , this thread is for the new version,which is not released as of yet.
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by the_big_1 View Post
    Hi,
    Quote Originally Posted by carputer1 View Post
    if you run trafficcams.exe in a skin it will not find the files in needs, hence the file not found error.
    please read the readme that came with the file you downloaded.
    E.
  4. #14
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    all i can say is. At last Trafficcams now looks the part in any skin now.lol....
    Thank you "E" for your input and hard work
    Gallery:
    Search:
    Map:
    Countries:
  5. #15
    Dec 2007
    Good news, first pic. Bad news second picture after about 15 TO 20 seconds later..
  6. #16
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    @brandensin
    is that just running rrtc and leaving the scr or on the scr without leaving, i have tryed everything , close rr - reopen , leaving rrtc from any scr to other scrs, with no problems , and i have had rrtc running for about 20min's so far , the cams refresh at intervals no problems. the only thing i don't have at the moment is map's .
  7. #17
    Dec 2007
    happens on both while on or off the trafficcam screen with trafficcam plugin still running in the background... so, i think it's happening while it's updating the image or something..
    by the way, is urs set to display something other than English in regional setting for non-unicode?
  8. #18
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @brandensin
    Brandensin's issue is to do with unicode support.
    I thought I had sorted it.
    brandensin, can you add debug=true to trafficams.ini and then PM me the debug.txt
    cheers
  9. #19
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just dl'ed USA , had to reloadskin for the search scr to work,
    once the db is installed , and reloadskin , after that the swap between db's is ok
    looks like the app needs to refresh its self, will test more on another country, really need a progress popup of the download.
  10. #20
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yep tryed it on another 3 db's reload needed on install of db before you can use it.
    may be if pos. to have the script reload its self once the db is dl'ed
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
