i was then i had some brain activity, so had to hit the keyboard again.
leaving rr alone is not going to make things better , but it was a break certainly needed.
cheers for looking into it E
Nice looking skin there.
I thought you were taking a break?
You might be able to do that with RR Skincommands.
But let me take a look tonight.
I think i have done it, cams are changing in the gallery scr, but have to reloadskin for them to take affect, which has nothing to do with your plug, my net and this system are so slow when using RRTC it crash's from time to time. i know i have a major internet problem with my provider at the moment.
o all i did is add EXIT||RRTC_1_CAM
Cheers E
Yeah, that should do it.
Nice one.
Well I can only sort it out with help.
So I need you to enter debug=true into the ini file, and then send me the resulting debug.txt file when it crashes out.
Also let me know which version you were running at the time (I think the debug will tell me me, but JIC)
E-mail address is at the bottom of most of my website pages.
tried to install the plugin version.... but it does not show up in menu...
but it might be because i dont quite understand this:
how do i perform those 2?You will also need to create a button in your menu.skin (or another .skin file) with the code rrtc
You will then need the skin files, a set of example skin files are avilable in therelease thread
Im a newb, how do you add x,RRTrafficCam to the menu.skin?
