Page 8 of 19 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 187
Thread: RRTrafficCam - Traffic flow cameras - Status : Released
  1. #71
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I have just done a quick harvest and test.
    I now have all the Dallas ones, Fort Worth will be a pain so may not make the next DB update, Amirillo should make it (about 6).
    I may have some more florida ones which I need to harvest and check so it may delay the new DB for a short period.
  2. #72
    Dublin
    i dont think the irish sites are working on this any more either - any chance you could check that please ?
  3. #73
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by djtaz View Post
    Unfortunately it looks like Dublin have cut down on the amount of cameras they have.
    However most of the ones that still work now have lat and lon coords.
  4. #74
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by Enforcer View Post
    Looks like the main URL has changed.
    Let me see if I can change it and add the extra ones at the same time.
    However, I would like to ask you a favour (or two).
    1. Can you get the GPS coords of the cameras once I put them in the database. (FAQ in post #2)
    2. Can you get a NMEA log of some driving around and about the area (I want to test the cameras by GPS Co ords) I can supply an exe to make the log if necessary.
    Would you need this for the Detroit Cams?
    If you cant DODGE em, RAM em.
  5. #75
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Ramanator View Post
    Yes please, any of the cameras in the database that don't already have them.
    Cheers
  6. #76
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Actually the original Dublin ones have been reduced in number, however there are now some more for South Dublin.
    Have updated database with those.
  7. #77
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    US database updated to US013
    Dallas TX corrected + some added
    Amarillo TX added
    Austin TX added
    Jacksonville FL added
    Added - but may duplicate some already in there.
    Minneapolis MN
    St Pauls MN
    Rochester MN
    Duluth MN
    St Cloud MN
  8. #78
    Constant Bitrate ramez75's Avatar
    Dec 2006
    Nazareth PA
    I downloaded the TrafficCam and unzipped it into the Road Runner Folder. In the Trafficcams.ini I changed country=UK to country=US nothing happened the only country code that works is country=UK. AM I missing something. I looked in the Databases folder and have only TrafficCams.E4X....
    Also the only skins i can use are Default and iDrive. I added another folder in the Skins folder Carwings and changed the Skins=iDrive to Skins=Carwings in the Trafficcams.ini, I got a runtime error..
    What am I doing wrong
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You have downloaded the standalone version of Traffic Cams.
    You would be better off downloading RRtrafficCam the RoadRunner plugin.
    As for the Database issue, please read the FAQ at the beginning of the thread.
  10. #80
    Dec 2006
    Nazareth PA
    Enforcer,
    Where do I download the RRtrafficCam plugin. I logged into your website and there is one Traffic Cam download which the i am using and it is the standalone version. I tried RoadRunner Plugins Gas/Petrol/TrafficCams/Upd8/Stopwatch/Grid take me to the same Standalone.
    Thank you
  1. Traffic Cams International v1.3.0 (1.4 Beta available)
    By Enforcer in forum Other Cool Stuff
    Last Post: 02-13-2011, 11:48 AM
