GPS Events [Coming Soon]
This is a GPS Events plugin which replaces the old broken and now removed native RR Reminders feature added by Sonicxtcy02.
I will post up some screens after I create my own versions of the DFX version screens that I'm currently testing with.
Current Features:
-6 different event types:
--Road Hazard
--WiFi Hotspot
--POI
--SpeedCam
--TollBooth
--Custom
Each event has:
-two actions, a warning(approaching) and Arrived with a distance count down using progressive distance scalling.
-two note labels which are diplayed on the event screen when the warning is executed.
-two RR variables, which are set when the waringing is triggered for use of outside apps to act upon.
-Ability to be deleted when no longer needed/wanted.
The first 5 are click-n-save with no further action needed. With these 5 events there are
predefined warning distances which can be changed via ini settings. These are also one way directional.
The Custom event is where you have full control over every event's setting.
Custom event features:
-Add/Delete the name for an event which also remembers that name's location.
-Add/Delete notes, which is good for adding a quick note pick up milk on the way home w/o retyping that note again.
-Set the warning distance for each event
-Directional setting, one or both directions
More to follow....
Hmmm Guess you cant "reserve" another spot now :)
I am back and waiting for news :-)
Updated first post with feature stuff.
omd this is what i am looking for since ages! one way directional. does this mean it is checking if you are moving towards/away to gps coordinates, i.e. speedcam on other side of the roads are not warned.
how is the approaching alghoritm - only if being nearby (circle) or taking an angle into considieration?
Yes Yes
I am waiting too this plugin
I just got the plugin from Blue for testing, and it is really coming along nicely! Wow! this is gonna be kick butt when it is finished!
With a simple tap of "Road Hazard" you can mark a place where say a pothole is. One tap of the screen to set a marker for a toll booth, speed camera ect... You can also manually edit the .dat file and add all of your speed camera's on the desktop PC and transfer to the car.
Lots and lots of options.....
