Page 1 of 8 12345678 LastLast
Results 1 to 10 of 78
Thread: timer ext plugin now RRsched
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    as suggested by blue , who will monitor this thread and is willing (time allowing) to make changes where needed and are possiable to add.
    thread rename , due to the change of the plugin it is no longer just a
    timerexec, it is now a calender of sorts , with the ability to set times and different cmds to anything in your exectbl.ini
    Current coding format
    you can use this <DATE>;<TIME>;<OCCURANCE>;"<ANY NUMBER OF CMDS, SEP BY "#" >";<Name of skin ( needed/wanted? ) >
    Example would be like this:
    09/08/08;13:25;O;"SENDMGS;MYAPP;HELLO||AUDIO#DVD#VIDEO"; DFX 4.0
    This makes:
    Date = 09/08/08
    Time = 1:25 AM
    Occ = Once
    First Cmd = "SENDMGS;MYAPP;HELLO||AUDIO"
    Second Cmd = "DVD"
    Third Cmd = "Video"
    If no skin name, will trigger the cmds on time set for all skins
    adding the skin name to the end of the line will make the cmds on time set
    only work in that skin. Indicators added to the days to indicate a an event has been inputted on that day.
    so far achieved,
    Month calendar days display if event(s) for that day.
    Clicking on an evented day brings up a listing of days events
    Clicking on the month at the top of calendar brings up a listing of all events for that month with -/+ months on that scn to nav around.
    can now set time for each event via custon numosk or hours and minutes buttons .
    you can now also set when you want your event to be triggered by selecting day of the week (mon.tues,wed,thur so on), yearly,monthly,so on.
    adding events or editing not implement as of yet.
    plugin once fully released, to set times for theme changes.
    set an alarm for appointments (in chucks case TV shows lol). Additional coding will be needed to run some ideas , but this plugin has opened up the possabilitys for skinners and users alike,
    latest beta test from this post Here
    Suggestions made:
    Genric timer
    execute exectbl cmds
    Time checking on start of Road Runner
    support for Hibination and standby
    Settings saved to plugins own ini
    Multiple cmds can be set for each time
    will update as i find out more.
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    why not make it a generic timer ... that can read one or one hundred events stored in an INI file and then launch an EXECTBL cmd at each event ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That would be the general idea...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jul 2007
    Ireland
    cool ...
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    The problem with using this TimeExec.dll for day night setting is if you open RR in between these times set it will not trigger your commands.
    You would have to do some fancy RR coding in the ExecTBL.ini file to get it to work for day/night.
    I use it for alarm clock to play sounds, go to player and play a station, play a preset in audio, play TV, record mic or record a player. Also a hourly chime and speak hourly weather and more.
    2001 S10 ZR2
    Chucks Skin - to old
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    ...with the ability to back check times to see if any of user set events have occurred (i.e. coming out of hibernation, powering up, etc.)
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yes agreed chuck as stands it dose not check onskinstart this will have to be addressed
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Very esay to add/do...next
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I don't know, how many events are there? What do you want it to do? I have only 2 events to trigger, this is day and night switching. For that I wrote the auto background changer. It changes the skins background and gamma setting sunrise and sunset times or custom times set in skin.ini. No matter when you start RR or come out of hibernation/standby, it will trigger the event.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this is 1 reason yes , i do like ai but a dll is mch better , if the timer is updated to todays standards then all these plugins that may need a timer feature like reminders don't have to have a timer built in them and you can set triggers off for others events,
    there has to many reason on why update this plugin i just feel it dose need updating the way some of these skins are going , its another feature which can be used.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
