Frequently Asked Questions.
Q. I don't have an internect connection in my car, can I still use this.
A. Yes, run this on your home PC save the info to your saved folder and then copy the saved folder to your Car PC. This can also be done from the Standalone version if you do not run RR on your home PC
Q. I put in a new zipcode but the stations haven't changed or updated.
A. It is most likely the site does not have any stations near the zipcode you have entered or you do not have a connection to the internet.
Q. I don't have any Carburant Station brand icons.
A. Look in your RoadRunner folder, there should be a folder called gas which contains all the gif files. However there may be some French specific ones missing so download the attachment at bottom of this post.
Q. I have the gas folder but I still don't have any Gas Station brand icons.
A. For the icons to work you will need the last RoadRunner version released by mitchjs or the lastest RideRunner
Q. You have done RRGas for the US, UK and France any chance of doing it for <Insert Country here>?
A. If you can find a website for your country that show the prices against individual stations, is searchable by postal code or GPS coords and doesn't show the price as a graphic, then post a link and I will have a look.
Q. How do I set this up to work with my skin?
A. Download one of the example skins and copy the commands from that also read the carburantskincommands.txt You should also bea bale to use graphic files designed for RRGas and/or Petrol
Q. Would someone care to send me this?
A. The Terms And Conditions expressly forbid the distribution of this program, please register on my forum to get your copy.
Q. Anyone have a screen built for <Insert skin name here>? it would be greatly appreciated!
A. check the skins thread, contact the skinner or you can try and convert it yourself (basic instructions earlier in the F.A.Q.)
Q. How can I download this wonderful creation?
A. Register on my forum at www.en4cer.co.uk/forum , when activated go to the downloads section.
Q. I have registered on your site but am still not activated, why?
A. I do not monitor the forum registrations 24/7 so it could take hours or possibly a day or two before I can activate you. If I am going away I will normally put this info into the news section of the forum. If however after a few days of registering you have not been activated then contact me via PM here. Using the same username as you do on here will help you get activated quicker.
LinkBack URL
About LinkBacks
