I try to use the kml commands but nothing run for me.
A folder for the kml files must to be defined ?
cool, thanks for the feedback.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
= to save HotSpots info to kml, RR MUST have access to gps data; =
= this kml file is saved in, .\My Documents\RideRunner\Plugins\WifiMan =
part of Skin Commands.
honestly i didn't test this features that much, all the test i did were done using skintool, and all of my test were good. if you can post the code and/or the skin files you are using.
I tried WifiMan on the move today and was really surprised at the speed it scanned and identified networks...it was very fast- well done guys! Unfortunately, 98% or more networks are secure and the only network I have in my Windows network connection list is my home network so testing profiles is going to be a little harder.
Thanks, more testing to come...........
Vauxhall Astra SXi Car PC installed.
cheers for the feed back dave , as far as i'm aware your the 1st to take this on the road lol... i'm amazed you get any wifi's in that vast waste land you live in lol....
Ok,
Actually, the wifiman install don't create the folder .\My Documents\RideRunner\Plugins\WifiMan.
I have created this folder and use the 'wifiman_kml_add' but i don't see a kml file .
(In the skintool, i see that: 'Command Not Executed: wifiman_kml_add')
Is it possible to define another folder by setting may be in other wifiman version ?
How can i to define the settings? May in the skin.ini like that ?
Code:WifiMan_Nets=infrastructure/add-hoc/add-hidden WifiMan_Locked=true/false WifiMan_Sort=signal/ssid
I have tried that in my skin.ini:
and that for the button:Code:[WIFIMANAGER] WifiMan_Nets=infrastructure WifiMan_Locked=true WifiMan_Sort=signal
Code:/, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,409,215,168,58,"WifiMan_Sort", B,18,215,168,58,"WifiMan_Nets", B,211,215,168,58,"WifiMan_Locked", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L01,18,224,168,38,255,255,255,20,"Arial","BYVAR;WifiMan_Nets;<<=Infrastructure<<=Add-Hoc<<=Add-Hidden","CENTER" L02,212,224,168,38,255,255,255,20,"Arial","BYVAR;WifiMan_Locked;<<=True<<=False","CENTER" L03,408,224,168,38,255,255,255,20,"Arial","BYVAR;Wifiman_Sort;<<=SSid<<=Signal","CENTER"
Looking at the ext pi src, it should have created the folder durring the ext pi initialization. That is why the createfolder func is there if needed, and you did uncomment it like you should have.
On another note, did you forget a file in the vb proj? I ask b/c I didn't see anywhere where the func ProcessExsits actually exsits?
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
these are not button cmds they are settings you need to set a byvar button cmd
Exsits?
This is where my Ex sits?
Eggs with zits?
what?
