Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 145
Thread: New Wifi Manager [Beta Ver. 1.2.0]
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by carputer1 View Post
    @pierrotm777
    Here's a example
    "LOCKEDNET","ByVar;WIfiMan_Locked;SHOWLOCKED<<NOSH OWLOCKED"
    "SHOWLOCKED",SetVar;WifiMan_Locked;true||SAVETOINI ;WifiMan_Locked;true"
    "NOSHOWLOCKED",SetVar;WifiMan_Locked;false||SAVETO INI;WifiMan_Locked;false"
    Ok , i have worked a little bit on the settings screen:
    i add these lines in my exectbli.ini:
    Code:
    /*********************************WIFI MANAGER by EL CAMINO*******************************
    "WIFITYPE","ByVar;WifiMan_Nets;WIFI_INFRASTRUCTURE<<WIFI_ADDHOC<<WIFI_ADDHIDDEN"
    "WIFI_INFRASTRUCTURE",SetVar;WifiMan_Nets;infrastructure||SAVETOINI;WifiMan_Nets;infrastructure"
    "WIFI_ADDHOC",SetVar;WifiMan_Nets;add-hoc||SAVETOINI;WifiMan_Nets;add-hoc"
    "WIFI_ADDHIDDEN",SetVar;WifiMan_Nets;add-hidden||SAVETOINI;WifiMan_Nets;add-hidden"
    "WIFILOCKED","ByVar;WIfiMan_Locked;SHOWLOCKED<<NOSHOWLOCKED"
    "SHOWLOCKED",SetVar;WifiMan_Locked;true||SAVETOINI;WifiMan_Locked;true"
    "NOSHOWLOCKED",SetVar;WifiMan_Locked;false||SAVETOINI;WifiMan_Locked;false"
    "WIFISORT","ByVar;WIfiMan_Locked;SORTBYSIGNAL<<SORTBYSSID"
    "SORTBYSIGNAL",SetVar;WifiMan_Sort;signal||SAVETOINI;WifiMan_Sort;signal"
    "SORTBYSSID",SetVar;WifiMan_Sort;ssid||SAVETOINI;WifiMan_Sort;ssid"
    that on my skin.ini:
    Code:
    [WIFIMANAGER]
    WifiMan_Nets=infrastructure
    WifiMan_Locked=true
    WifiMan_Sort=signal
    and my wifiman_settings.skin:
    Code:
    RoadRunner Skin
    RRScreen Random_Menu
    wifiman_settings_off.png,wifiman_settings_off.png,wifiman_settings_on.png,wifiman_settings_off.png
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,18,214,168,58,"WIFITYPE",
    B02,212,213,168,58,"WIFILOCKED",
    B03,409,215,168,58,"WIFISORT",
    B04,68,14,468,58,"ESC",
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font wifiman_settings, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,18,226,168,38,255,255,255,16,"Arial:b","=$WifiMan_Nets$","CENTER",,"DS=2,2,0,0,0"
    L02,212,226,168,38,255,255,255,16,"Arial:b","=$WifiMan_Locked$","CENTER",,"DS=2,2,0,0,0"
    L03,408,226,168,38,255,255,255,16,"Arial:b","=$Wifiman_Sort$","CENTER",,"DS=2,2,0,0,0"
    L04,68,13,466,60,255,0,0,36,"Arial:B","=!!Wifi Settings!!","CENTER",,"DS=3,3,0,0,0"
    /DISCARDABLE
    END
    But my settings don't change !
    Where is my error please ?
  2. #32
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i think there is a problem..when i disconnect from a network then reconnect (using the plugin) the status of the "WifiMan_Connected" indicator + all the labels ("WifiMan_Ssid" etc.) are not updated
  3. #33
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    did you change the words to your language in the info.txt , if you are not useing english OS
  4. #34
    Apr 2006
    Greece
    i am using an english OS..the labels are all updated when i first run RR..(and i am allready connected) if i disconnect then reconnect (usind the plugin) the labels are not populated..seems like WifiMan.exe is not refreshing?
  5. #35
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry just saw that you are in Greece had to ask, i don't get this problem here myself , we did in 1st testing the plugin , sometimes it takes a minute or so to refresh it waits till you are fully connected again .
    try enable and disable , see what happens there , the srcipt should close and open again, for this function not on disconnect the script stays open ....
  6. #36
    Apr 2006
    Greece
    and 1 more thing "wifiman_toggle" seems to try to run the script again and not actually toggle on/off...when wifiman.exe is run and i send a "wifiman_toggle" i get an error msg saying "allready running"
  7. #37
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yep you have just confirmed what i have recieved from another users they have the same problem with toggle , toggle is suppose to close the script , on disable and open script on enable , in some cases this is not happening , and we thought it was down to the OS language , needs to be looked at further ..
  8. #38
    Apr 2006
    Greece
    as for the refresh issue..i waited 5 minutes..nothing...maybe it is windows 7 to blame?
  9. #39
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    arh now thats a different story , this plugin will not work correctly under win 7 , its built around xp sp3
  10. #40
    Apr 2006
    Greece
    other than this problem it works nice in win7
    i will try in the car..i have XP sp3 there
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
