Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 145
Thread: New Wifi Manager [Beta Ver. 1.2.0]
  1. #61
    Nov 2006
    New to WiFiMan and encountered several errors
    First of all, well done.
    1. The profile list appears to be circular even though only one set of profiles is "CLADDed". My list definition is as follows (my on skins):
    Code:
    IL,CL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    SC,101,288,603,258,255,255,255,3,80,40,0,0,0,255,128,0,TRUE,20,"Lucida Sans Unicode"
    2. On a subsequent connect/disconnect cycle the data at the top of WiFiMan.skin doesn't update although it does go blank on disconnect. There are no SETVARs in debug.txt for the subsequent connects.
    3. On a subsequent connect/disconnect cycle, ONWIFIMAN_CONNECTED doesn't fire. Upon examining debug.txt it only appears to fire on start-up of there is an active connection.
    Regards,
    Jim
  2. #62
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by obrienj View Post
    Code:
    Regards,
    Jim
    i don't really understand your 1st Q
    2nd try exe attached should fix it
    3rd this is correct it only runs on rr start ,
    Attached Files Attached Files
  3. #63
    Nov 2006
    First issue fixed. I split WiFiMan skin into connection and support skins and the profile list worked fine.
    2. Will try .exe, if I still have the problem I will let you know.
    3. If it only fires at start-up what is the recommended way to know if there is an active connection and/or if the current connection has disconnected?
    Regards,
    Jim
  4. #64
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you can use the indicators
    wifiman_connected & wifiman_card_state
    or you could use the events cmds
    onwifiman_card & onwifiman_net
    found in the skin cmds that comes with the plugin.
  5. #65
    Nov 2006
    As to the data that is displayed for a connection, I see in skincommands.txt that the label (variable) names are in the form "wifiman_xxxxx" e.g. "wifiman_signal" and this is what is in the wifiman.skin.
    However, when I look at debug.txt, not only do I see variable names in the form "wifixxxxx" e.g., "wifisignal" being updated I also see that only "wifisignal" is updated when I connect after a disconnect.
    What am I missing?
    Regards,
    Jim
  6. #66
    Nov 2006
    El Camino,
    I'm sorry but I when look in debug.txt, I am not seeing any of the events fire except ..._Connected on startup and ..._Disconnect on the first disconnect.
    Nor am I seeing any of the variables or indicators being set after the initial connect.
    But the actual disconnect/connect works just fine.
    If you would like, as I am quite familiar with AutoIT, the WiFi UDF, DLLs for RR, and AutoIt use with RR and DLLs, I would be more than happy to take this offline.
    Regards,
    Jim
  7. #67
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    pm me, you're email.
  8. #68
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Unhappy
    I have found a little error into the osk.skin file:
    Code:
    K03,178,176,059,078,005,064,064,"'@"
    change by
    Code:
    K03,178,176,059,078,005,064,064,"@"
    I have an issue that don't understand.
    Some time RR don't run well if wifi manager is used !
    If i unregister the wifiman.dll file all is ok.
    Do you have an idea that happen ?
    This is my carwings screen when RR bug:
  9. #69
    lambosprit's Avatar
    Sep 2006
    UK
    Just tried this out and its working great. Thanks for a nice little app. Very useful.
  10. #70
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Request.....
    Can you make the plugin look in the skin folder to see if a WifiManIcons folder exists and if so, use it instead of the PI directory folder.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
