Yes, please & thanks. We have more custom vers for DFX and would overwrite exsiting ones in the plugin folder if there.
yea, i can make the PI look for a folder Named "WifiIcons" inside of the current skin folder, if not found, use the ones in the PI folder, is that good enough?
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
try this exe,
A Dfx beta tester said all is OK with new exe.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
[EDIT]
Didin't have newest dll
[/EDIT]
You NEED to update your first post with current version.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I am still having issues. I have Xp service pack 3. When hitting connect/disconnect device is being disabled
Ok, trying to add this to my skin and carPC
Seems to workpretty well but I have a couple of observations.
1. there seems to be quite a lot of reliance on commands in the exectbl.ini which should really be handled by the DLL itself, the settings buttons for example.
2. Wifiman.exe doesn't (or not at all) close when RR closes). This then causes the plugin not to work if RR is then restarted
3. The settings do not seem to be saving as each time I run RR and the plugin the settings have reverted back to their original ones.
and because I intend to add support to RRUpd8 to attempt a sync on your plugin connecting to a wireless network.
4. I think it would be better served if either the DLL handles the ONWIFIMAN_CONNECTED popup internally or you send a second ONWIFIMAN_CONNECTED type command,because at present the command will be translated in the exectbl.ini to the pop up and my plugin won't get the signal unless a command is added the the list. (unless RR handles userdefineable ON commands in the execbl.ini differently to normal commands.)
@Enforcer.
if you want the source PM me you're email, i'm not working on this for now, very busy at work, and the little time i got for coding, goes into another PI.
email is at the bottom of my webpage (contac web admin) cheers.
What's it written in?
is there a way to add it to the carwings skin? trying to figure it out, the test skin works
