Not Supported any more...
This PI is intended for NON COMMERCIAL USE ONLY..... you know the rest... AND you know i'm talking to you...
if you are getting any compensation using my PI you are NOT allowed to redistribute or support this PI..
Alpha release.
We have made this plugin alot more integrated in RR, instead of embedding,
now we use a CL list format, making it look a lot better than the old PI.
This allows skinners to also design their own screens and CL list icons.
Some Features :
CL list of Wifi's in range,
Your own images can be used for Saved Profiles
When connecting to a Wifi, if not saved as a Profile will attempt to save.
Hot spots can be saved to a kml file, and can be loaded to google earth.
SetUp Install :
Run Setup, then drop the test skin folder into your skins folder, This is a full working test skin.
Binary install :
Drop the folder named "WifiMan" into your plugin's folder.
use the Register.bat to reg the files needed to run.
drop the test skin (Carwings_Wifi) folder into your skins folder, This is a full working test skin,
just change your RRconfig setting to this folder or use skin browser if the skin you use has this option.
Language :
inside the wifi plugin folder you will find info.txt, simply change the words you find in there to your
OS language, Do not change the order or the layout, Just replace the English words for your Language.
READ Skin Commands.txt, for more info and minimum requirements.
Credits :
El Camino = Plugin Author
Carputer1 = Carwings Skin files & Testing
Valheru = Testing
Dartman = Testing
Davefoucus = Testing
any feedback is appreciated good or bad. it doesnt take much, take's less time and effort than it took me to create this pi.
______________________________________ [[[ 04.09.2010 ]]] ______________________________________
First Alpha Release :
______________________________________ [[[ 04.16.2010 ]]] ______________________________________
Some bugs killed :
Slider signal, kml add.
added a settings screen, in test skin.
______________________________________ [[[ 09.04.2010 ]]] ______________________________________
more bugs killed :
added a new setting, creates custom ONCONNECTED events, according to ssid.
"Already Running" popup disabled.
______________________________________ [[[ 11.04.2010 ]]] ______________________________________
updated to new sdk events handling :
code improve, makes label rendering a little faster.
changed event names to new sdk events standar's, to pass events to other plugins,
i.e. "ONWIFIMAN_CONNECTED" now is "*ONWIFIMAN_CONNECTED", read SkinCommands for more info.
RR Nov/2010 And Above Only.[/COLOR][/SIZE][/B]
Last edited by EL CAMINO; 02-13-2011 at 06:22 PM. Reason: New Version available, wont be able to suppont this one.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
i'll look into his install source and fix that
installer fixed in 1st post
Could of washed your Feet E
So far so good.
I'm hoping to develop an Elite Lite version of the skin after seeking suavecito permission. Only problem I'm having is needing a wireless for testing which slows skin development down a little (bearing in mind this is not my talent!)
Thanks for the opportunity to be involved! I'll keep you posted on testing results![]()
Vauxhall Astra SXi Car PC installed.
It is a very good and cool plugin .
Run very well on xp sp3, some problems on my vista. I test it actually .
Just a little thing, in the profile list, the pictures have not same size for width and height dimension .
i know about the limitations on vista/W7 , that's why is not recommended to use it. about the profiles images they do work very well. take a look,
on the next build you'll find you're requested indicator, called "WifiMan_OnProfile", displays an image from the connected profile if any.
Working good thus far.
Noticed that the wifi_signal slider bar reads half compared to the wifi_signal label.
Also during testing router switch to simulate 'out of range' and the wifi_signal indicator, bar and label failed to appear on router switch on without RR restart???..
Testing will continue tomorrow.....Thanks
