Page 11 of 38 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 377
Thread: GPS Gasoline RR Plugin: Now w/ iGuidance Support
  1. #101
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by mick0uziel
    i mod the alpine red skin replacing the GAMES button with GPSGAS and also replaced the logo, how do i paste the image in my quick reply so everyone can see it and if they want i can send it to them, anybody got an upload site? thanks
    ....waiting for new updates of this cool app....
    Reply with the "Go Advanced" button, then if you look at the bottom it says "Manage Attachements". Select your pic and upload. It's good for 2MBs...
  2. #102
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    It now works perfectly for me! Great prog Lost!!!
    Peace,
    Rafster
  3. #103
    Raw Wave lostreception's Avatar
    NY
    Thx new version by the end of the month
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  4. #104
    _
    Mar 2004
    Little Elm, Texas
    mad skills there lost! mad skills.
    I'm looking forward to implementing this in my car for our road trip this weekend. I think our friends will love us for finding the cheapest gas stations.
    I'm a bit unclear on a few things. Bear in mind, I'm no programmer, and the software side of things is still pretty new to me.
    First question is in the actuall install.
    I've made a 'gpagas' folder in my rr folder, and dropped the .exe in there. I've gone in and added the line you posted to the exectbl.ini file.
    Now, how do I get it to open in RR? I have to create a button? how do I go about doing this? Skinning is a WHOLE nother world for me.
    Perhaps someone might have this done and would be willing to share?
    Also, I'm trying to understand this fully.
    Lets say my friends and I are planning a road trip that will take roughly 7 hours this weekend. I will need to get this working and sync up BEFORE we leave, correct? How do I tell it where to look? Can i tell it to look along this certain route I'm planning to use?
    Put it this way:
    I'm sitting in my garage, getting ready to leave, packing up the car, etc.
    I tell iGuidance to navigate to Vance, Texas from McKinney, Texas using the shortest route. Then I go into GPSGas in RR and tell it to find the cheapest gas along that route?
    Or do I sync up, and have to go into the program manually and tell it to search for the cheapest gas.
    Without being able to run it yet, I'm a little lost as to how it works exactly.
    I'm sorry if this seems to be a remedial bunch of questions, but I'd appreciate any insight you could give!
    Jan Bennett
  5. #105
    NY
    Red
    in the skin that you are using if there is an unused button for example
    XM or Sirius
    then just add this above the other line of the execTBL.ini
    "XM","GPSGAS"
    this reassigns XM to the gas program
    you can use any button
    NOTE: this is more a quick fix once ive completed the progra ill make a default skin for it as well
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  6. #106
    _
    Mar 2004
    Little Elm, Texas
    hrmm - ok - so I'm using the standard skin that RR comes with when you download and install it (the one with the BMW logo in the middle). I'm playing with this on my work computer for now, so I didn't care so much about the skin.
    Here's the .ini file as it came with the last rows added by me.
    Code:
    /, This (OPTIONAL) file contains translation commands.
    /, RR will accept the commands defined on the LEFT
    /, and execute them as expressed on the RIGHT
    /, you can use this to create or redefine any command
    /, (or to add functionality to any syandard command).
    /, The Format of this file is (by choice):
    /, "<COMMAND>","<EXEC COMMAND>"
    /, "<COMMAND>","<EXEC COMMAND>",filename.skin
    /, Examples:
    /, "AUDIO","LOAD;audio_player.skin;Audio Player"
    /, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
    /, Extas:
    /, XM, FM and MM can be used instead of a skin file
    /, to be translated when XM, FM or MM is turned ON.
    /, PLAY, PAUSE and STOP can be used instead of skin
    /, file name so it executes commands based on MP3 or
    /, Video playback status.
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    /, Set Bellow the Path to the CDRip plugin (if used)
    "CDRIP","PLUGIN;RRCDRip;C:\VBStuff\Road Runner\CDRip\CDRip.exe"
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    "ONSUSPEND",""
    "ONRESUME",""
    "ONLINE",""
    "OFFLINE",""
    "ONFILECLICK",""
    "ONDIRCLICK",""
    "ONPLCLICK",""
    "ONDLCLICK",""
    "ONPBCLICK",""
    "ONPLSELCLICK",""
    "ONDLSELCLICK",""
    "ONSONGSTART",""
    "ONSKINSTART",""
    /, For MediaCar Compatibility only:
    "AUDIONEXT","RRNEXT"
    "AUDIOPREV","RRPREV"
    /, OSK Gestures (Changes not recommended)
    "GEST-A","A",osk.skin
    "GEST-B","B",osk.skin
    "GEST-C","C",osk.skin
    "GEST-D","D",osk.skin
    "GEST-E","E",osk.skin
    "GEST-F","F",osk.skin
    "GEST-G","G",osk.skin
    "GEST-H","H",osk.skin
    "GEST-I","I",osk.skin
    "GEST-J","J",osk.skin
    "GEST-K","K",osk.skin
    "GEST-L","L",osk.skin
    "GEST-M","M",osk.skin
    "GEST-N","N",osk.skin
    "GEST-O","O",osk.skin
    "GESTURE-P","P",osk.skin
    "GEST-Q","Q",osk.skin
    "GEST-R","R",osk.skin
    "GEST-S","S",osk.skin
    "GEST-T","T",osk.skin
    "GEST-U","U",osk.skin
    "GEST-V","V",osk.skin
    "GEST-W","W",osk.skin
    "GEST-X","X",osk.skin
    "GEST-Y","Y",osk.skin
    "GEST-Z","Z",osk.skin
    /, Global Gestures
    "GEST-M","AUDIO"
    "GEST-X","EXIT"
    "GEST-H","MAIN"
    "GEST-L","LOAD;AUDIO_BROWSER.SKIN"
    /, Car2PC Interface Support
    "HUSTART","RESUME"
    "HUSTOP","PAUSE"
    "NT ","RRNEXT"
    "PT ","RRPREV"
    "PA ","PLAY"
    "FF 1","STARTFFWD"
    "FF 0","STOPFFWD"
    "FR 1","STARTFRWD"
    "FR 0","STOPFRWD"
    "DS 001","AUDIO"
    "DS 002","VIDEO"
    "DS 003","RADIO"
    "DS 004","XM"
    "DS 005","GPS"
    "DS 006","DVD"
    "MX 1","SHUFFLE"
    "MX 0","SHUFFLE"
    "RP 1","REPEAT"
    "RP 0","REPEAT"
    /, GPSGas
    "GPSGAS","LOAD;EXTERNAL_GPS.skin;GPSGas;C:\Documents and Settings\jsanders\Desktop\Front Ends\RoadRunner\gpsgas\GpsGasolinev0.6.5.exe;GPS Gasoline”
    One issue, I don't see where it would call another program (function?) in that file. I don't see where I could take a function and remap it is essentially what I'm getting at.
    Am I overlooking something?
    Thanks for the help!
    Jan Bennett
  7. #107
    NY
    try this
    Code:
    /, Examples:
    /, Extas:
    "BYE","QUIT"
    "ONSUSPEND",""
    "ONRESUME",""
    "ONLINE",""
    "OFFLINE",""
    "ONFILECLICK",""
    "ONDIRCLICK",""
    "ONPLCLICK",""
    "ONDLCLICK",""
    "ONPBCLICK",""
    "ONPLSELCLICK",""
    "ONDLSELCLICK",""
    "ONSONGSTART",""
    "ONSKINSTART",""
    /, Global Gestures
    "GEST-M","AUDIO"
    "GEST-X","EXIT"
    "GEST-H","MAIN"
    "HUSTART","RESUME"
    "HUSTOP","PAUSE"
    "NT ","RRNEXT"
    "PT ","RRPREV"
    "PA ","PLAY"
    "FF 1","STARTFFWD"
    "FF 0","STOPFFWD"
    "FR 1","STARTFRWD"
    "FR 0","STOPFRWD"
    "DS 001","AUDIO"
    "DS 002","VIDEO"
    "DS 003","RADIO"
    "DS 004","XM"
    "DS 005","GPS"
    "DS 006","DVD"
    "MX 1","SHUFFLE"
    "MX 0","SHUFFLE"
    "RP 1","REPEAT"
    "RP 0","REPEAT"
    /, Changing XM button to call GPSGas instead
    "XM","GPSGAS"
    /, GPSGas
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  8. #108
    _
    Mar 2004
    Little Elm, Texas
    done.
    now when I go into 'Entertainment' > 'XM Radio', I essentially get a wrapper. It puts FireFox inside RR. I don't get a screen shot like I'm seeing being posted.
    What does this indicate that I am doing wrong?
    Jan Bennett
  9. #109
    NY
    Quote Originally Posted by Red GTi VR6
    done.
    lol nothing just close this window cause it contains the words "GPSGasoline" and it thinks this window is GPSGas
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  10. #110
    Apr 2006
    Washington, DC
    Quote Originally Posted by lostreception
    lol yeah I've done this myself a few times
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. RR lower volume for GPS Directions
    By UM_Fan in forum Road Runner
    Last Post: 02-28-2006, 11:46 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR forgets GPS port!!!
    By eduardovdr in forum Road Runner
    Last Post: 07-17-2005, 06:11 PM
  5. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
