yea what format should it be in cause ill be getting the gas station coords/address from the online sourceOriginally Posted by PURDooM
sweet igudance intergration !!!!!!
i wanted to do it but i was gonna use autoit this will be even sweeter
thx PD
Excelent idea!
Do you have gps coordinates (lat/lng) or addresses to the gas stations in your database? Either way, I could hook you up with a function to input the destination into a running instance of iGuidance. I would just rip it out of my iGPOI program I never finished.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
thx PD
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
Gps coordinates are better, thats what my function does right now it jut finds an open copy of iguidance and puts a pair of lat long coordinates in.
Ill dig out my code off of my backups when I get off work!
that may be a bit harder but ill do my best
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
cool app! Is there any way of finding out when the data for a particular gas station was last updated?
next release will have that and much moreOriginally Posted by sandworm
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
purdoom im researching the way this is working out and due to address discrepancies this isnt going to be easy
for ex
251 Route 130 could be:
251 RT30
251 SR-30
251 CR-30
251 RT30 N
251 RT 30 S
and so on
i can use regular expression pattern matching maybe but its still a bear to tackle
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Excellent idea, I think this what you call thinking outside the box
lost, you can use Yahoo Maps to calculate the Lat and Lon. It's pretty tolerant when it comes to street name variations. The only downside is you need Internet access but I figure you'll need it for this plugin to work anyway.
LR:
If you can pull phone numbers of gas stations, you can put it into superpages reverse lookup at this url:
http://yellowpages.superpages.com/yp...0&E=&T=&S=&Z=&
And then view the map view (example is (763) 323-9248 )
http://yellowpages.superpages.com/li...search=Find+It
http://yellowpages.superpages.com/su...e=MN&zip=55303
And into the URL of the map is some gps coordinates. Can you screenrip that?
