I got a "Missing DAO" at the inital load. It seems to load fine now though. Also, do I have to manually put in the Lat/Long each time or should it log it to a file? It does save the html file for my zip code just not the coordinates.
Known Bugs:
Some peeple report missing files on initial load please let me know of any dependacies so that i might fix this
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
If anyone has the Missing DAO or Missing RichTX32 errors and they keep occurring, the fixes are here:DAO Fix and here: RichTX32 Fix
I will be updating my post and the website with bug infoOriginally Posted by Gixxer
Well if you are going to use it that way i can add that function if you like but its main purpose is simplicity so that you dont have to enter anything. run it in your car with the gpsport of your gps com split into rr so that rr displays the lat lon then gps will need no interaction at allOriginally Posted by Gixxer
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Originally Posted by lostreception
I'm getting "Run-time error "5"
"Invalid procedure call or argument"
running version 0.6.4
This happens when I press the "search" button.
Also on initial load every field on the screen blinks on then off before the seach screen loads.
Great application, this is what make a carpc truely useful...Paul
NOTE: I do NOT have an active internet connection when I test this on my carpc, on a desktop with an internet connection it is running just fine. Might be irrelevant but maybe not???
Perfect, that's what I was wondering. So just split the ports with Xport3. and it should be good to go?
Thanks again.
yup have rr run the gps or wait for the version fo this whic is standalone then split the feed into this app by itselfOriginally Posted by Gixxer
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
the blinking i have not seen yet but the runtime error is most likely because its not getting internet i need to take a look at thatOriginally Posted by pshadwick
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Looks like you are correct about the internet connection, I connected the carpc (the one that wasnt working) and it is now fine.Originally Posted by lostreception
The app needs to run whether connected to the Internet or not. I will usually only connect the carpc when I need to.
Running the app standalone and NOT maxamizine the screen prior to pressing search I do NOT get the blinking. As soon as I maxamize the screen, or when it is running within RR it blinks when it is first loaded or when you press search for the first time. It's done this on all 3 PC's I've tried. No big deal it only seems to happen the 1st time.
On my CarpC set at 1024 x 768 (whether standalone or in RR) The line "Last Updated ........... Closest Zip" has a line right throug the midle of it.
I'd get rid of the "Are you sure you want to exit GPS Gasoline" in RR it's just a nuisance
Another subject... I had previously posted a question about getting weather by location. My simplistic solution was to automatically update rr.ini (Weather City=nnnn) from GPS. While a much more elegant solution is available, if the current city could be made available from your program it would answer my question.
Thanks...Paul
the last bit about the weather ill do that thats easy enoughOriginally Posted by pshadwick
the flashing i did notice as well now that u mention it
the line part is something with the resizing of the controls im not that good at it lol
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
