Page 7 of 38 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 377
Thread: GPS Gasoline RR Plugin: Now w/ iGuidance Support
  1. #61
    Raw Wave lostreception's Avatar
    NY
    Some Progress
    • fixed the internet bug (it seems)
    • also i made it so that when clicking exit the popup does not appear
    • clicking exit also sends a Cancel Command to Roadrunner thus allowing the app to be run fullscreen if desired
    Temporary release - Gas distance not enabled but works when it is and moved instruction screen
    www.w3bma5t3r.com/gpsgasoline/GpsGasolinev0.6.5.zip
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  2. #62
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Awesome trying this out today
    ````` _____||.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  3. #63
    Nov 2005
    Missouri
    Quote Originally Posted by lostreception
    Some Progress
    Tried the new release, On my desktop with Internet available it works fine.
    On my CarPC with no Internet I get a different problem. Where it crashed previously now when I press "Search" it locates the zip code but that is it. No city name and no gas stations.
    I can try the carpc with Internet this evening.
    ...Paul
  4. #64
    NY
    Quote Originally Posted by pshadwick
    ...Paul
    it is working correctly then
    the city name and station ifo is requested via http (url)
    glad to see it fixed it
    now to figure out cacheing
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  5. #65
    NY
    Update 05-16-06 Beta 0.6.5
    • Made Inno Installer
    • Cacheing support of previously ran stations (with the exception of geocoding)
    • Geocoding option (see zipsettings.ini) Default True
    • Fixed no internet bug
    • Removed Black instruction screen on initial load
    • Fixed Serial Port Bug
    • Removed horizontal line It was causing alignment problems
    Known Issues
    if geocoding fails it returns city center or inaccurate address
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  6. #66
    Nov 2005
    Missouri
    Better or worse?
    im thinking a few buttons added like:
    closest gas
    cheapest reg
    cheapest plus
    cheapest premium etc
    and of course a navigate to location button as well
    EDIT changed picture
    Based on the need to have Internet always available for this application I just updated to unlimited data on my cell plan. This app. is what makes it worthwhile.
    I like the idea of directions to the gas stations (your post 40), although I'd like it for all 4 stations listed. Address and direction (perhaps point N, S E, W, SE etc) and distance (as you showed).
    Perhaps a button to sort by nearest location or lowest price (for your selected grade).
  7. #67
    NY
    NSEW isnt as easy as i thought i can get the correct needle position for example i can figure out if its (ne or sw) (east or west) etc but one thing that happens is
    the station will be to the east and it will say west
    the station will be south east and it will say north west
    OR it will work fine but i havent figured out how to fix it yet
    sorting i will implement as soon as possible
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  8. #68
    Nov 2005
    Missouri
    Donation sent.
    I notice the image isnt displayed for Phillips 66 even though there is an image in the folder.
    What is the syntax for the images, can I add new ones? (MFA is big locally).
    Removing the line eliminated that problem, but at full screen the text related to the station and the station info is a bit disjointed. Might need a box around each station?
  9. #69
    NY
    Donation sent.
    Thanks very much for the donation its appreciated
    can you post some screenshots of what you mean by disjointed
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  10. #70
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    hi, this is an amazing tool congratulations. i am trying it on my desktop, how come the distance are all the same for all gas stations (7950.2 miles away) and why so far away? did i miss any settings? zip is correct, it picks it up from mapmonkey, address seems correct too. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. RR lower volume for GPS Directions
    By UM_Fan in forum Road Runner
    Last Post: 02-28-2006, 11:46 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR forgets GPS port!!!
    By eduardovdr in forum Road Runner
    Last Post: 07-17-2005, 06:11 PM
  5. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
