ok how do i make this app sit inside the RR skin? it keeps on showing up on the center of the screen instead of inside rr skin? thanks
also, is there a way to just click that gas icon or address and mapmonkey will navigate you to that station automatically? thanks again
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
I'm not sure about the other two issues you have, but for this one, you have to make sure you are using the correct "Window Name" for the program in the skin that you're trying to embed it to. Should be "GPS Gasonline" When you don't use the right window name, RR won't embed it. Happened to me the first time ;-) but that's back when the window name was "GPS Gasoline - by Lostreception" lolOriginally Posted by mick0uziel
this is my button code from my apps page. lol yeah, it shares the netstumbler skin, cuz I got a bit lazy there:
as you can see I'm a version or two behind in the beta testing... sorry lost :-)Code:B,138,291,223,68,"LOAD;netstumbler.skin;GPS Gasoline;C:\Documents and Settings\HTPCUSER\Desktop\GpsGasolinev0.6.13\GpsGasolinev0.6.13.exe;GPS Gasoline",
EDIT: Lost also has the install instructions on the GPS Gasoline webpage.
I'm not sure how to post a screen shot (perhaps someone could enlighten me).Originally Posted by lostreception
Basically the problem is only apparant when the screen is large.
The 4 squares with the gas prices are nicely spaced across the bottom portion of the screen, but the address is well to the left and well above the prices, the station logo and directions are even further up.
The info for the 2nd station is so far to the left it's almost over the 1st stations prices (same for 3rd and 4th).
The text either needs to be closer to th eprices or there needs to be a box around the station and all it's info so It's clear what goes with what.
Well I'm assuming you already have the screenshot... lol so just post a reply (not the quick one) and look at the bottom for "manage attachments". Select your pic and upload.. add a reply and post. There is a file size limit... I think it's like 2Mb, so you 'should' be good. lolOriginally Posted by pshadwick
Screen attached ( I hope)
Re screen shot.
As you can see the image "Hess" is a long way from the prices for the Hess gas station.
Another question... What is the date and time of "Last Updated"
It's not the last time I pressed "Search" (off by a couple of hours).
Is it the last time the web site the prices came from was updated?
...Paul
yes the websites time also the resizing is probably the one thing that will be the hardest to do (for me) it was designed for 800x480 or 800x600 it looks like crap at 1024x768 and anything above 800x600 do you use that high of a res on your carputer? if so what is your res ill try to make it fit correctlyOriginally Posted by pshadwick
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
i dont use mapmonkey but it might be pretty easy bacuse roadrunner does support itOriginally Posted by mick0uziel
ill add it to my todo list
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
if the geocoding doesnt get its request to the internet the ditance will be incorrect. now that u mention it i know how i can fix it so that it wont show if its doesnt get the informationOriginally Posted by mick0uziel
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
