Page 1 of 38 1234567891011 ... LastLast
Results 1 to 10 of 377
Thread: GPS Gasoline RR Plugin: Now w/ iGuidance Support
    Raw Wave lostreception's Avatar
    NY
    Talking GPS Gasoline RR Plugin: Now w/ iGuidance Support
    Beta Release - 09-01-06
    Download:
    GPS Gasoline v0.99
    Demo Video: (Added 09-04-06)
    Link
    Special Thanks to W3bMa5t3r for hosting the files
    GPSGasoline v 0.99 Features
    - Full DLLPlugin Integration
    - iGuidance Support (Currently 2.x only) I Dont have 3.0 but will try to support it
    L Support for adding station as Stopover or New Destination
    - Configurable (If automotive.com changes thier format you wont be without gas prices as the script is set to Validate the data as its sent)
    - Auto update Timer Support (Set by buttons or custom in the .ini)
    - Manual Zipcode Mode (For When GPS is unavailible or your bored)
    - Current Compass heading to Location
    - Current Surface Distance To Location
    - Home Longitude and Latitude Support (For When GPS is unavailible on initial load)
    Future Releases:
    - Cache Builder (No internet Required)
    - Support for other gas/movie/weather sites
    - Price Alert Popups
    - IG3.0 Compatability
    - Freedrive Compatability
    - Other GPS Programs......
    Description
    GPS Gasoline takes your longitude and latitude (from Road Runner) and converts it to the nearest zipcode based on that data.
    It then takes that zipcode and sends a request to the internet for the gas prices in that area
    using
    Then you can browse thru the stations and see where the cheapest gas is where you are located.
    Requests are welcomed, but keep in mind this is my 1st program I've written
    Installation
    UNINSTALL PREVIOUS VERSIONS!!!! REMOVE and EXEC.tbl entries related to gpsgas
    NEWEST RR 7-8-06 Recommended Also works with IGNative version
    Run the Install File and Run the Wizard
    Apparently the installer is not registering the dll so you will have to do it manually
    go to run and type
    regsvr32 "c:\program files\road runner\gpsgasoline.dll"
    where c:\program files\road runner\ is your path to roadrunner
    add this line to your menu.skin
    Code:
    X,GPSGasoline
    Then make a button in Roadrunner with the Button Code "GPSGAS"
    That's it
    Donations
    Code:
    pshadwick                     10.00
    Code:
    GPSGasoline To Do List:
        - Allow to save data to a database
        - Allow to read GPSdata (NMEA) in standalone
        - Improve on ability to load data from other sites (gas related or not)
            - improvingcacheing
    Build History
    v0.5 - First Release 4-22-06
        - Manually able to enter Lat Lon to get desired zipcode
        - Ability to pass that zipcode to a URL and retrieve the HTML page
    v0.6  - Beta Release 05-14-06
        - Added graphical interface
        - "BASIC" cell picker to customize site data
        - Polls Lat Lon from Roadrunner Via SDK
    v0.6.5  Beta Release 05-16-06
         - Made Inno Installer
         - Cacheing support of previously ran stations (with the exception of geocoding)
         - Geocoding option (see zipsettings.ini) Default True
         - Fixed no internet bug
         - Removed Black instruction screen on initial load
         - Fixed Serial Port Bug
         - Removed horizontal line It was causing alignment problems
    v.07  -
        - Compass heading to each station relative to users Lat Lon
        - Very Limited loading of data from other sites
        - Distance to each station (done)
        - Improving GUI
        - Sorting results
        - Skins
        - More Suggestions
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Awesome, can't wait to give it a run :-) ... subscribed
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    You sir.... are the freakin' BOMB!
    oh this has TONS of apps.. Nearest MyBank.ATM, weather, traffic... etc
    If you need any resources to make this happen... let me know
    (Hosting, $$, research etc...)
    V/R,
    •Micke
    NY
    Updated 1st post
    just something to play with for everyone right now
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Apr 2006
    Washington, DC
    Woohoo!! it separates it by fuel type as well... great for us 'premium gas' users... lol. That’s the only price I'm concerned with. The difference between regular and premium can be a major difference from station to station so if you can only see the regular... you could be SOL... look'n sweet. Thanks!!
    Oh, ditto on the post for hosting... I can host as well if need be...
    Thanks again... Peace
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Thisi looks very interesting. Look forward to having a play with this. Thx LR.
    NY
    Next Release will have a better interface and RR intergration
    Also thought I might mention this 2 options here
    • I can make it a live data request tool meaning that you request gas it brings it up OR
      you have the computer connect to the internet at a given time and it will request and build a list of stations for you with in a certian mile radius or certian zipcode number (keep in mind some zips offer 2 or more towns worth of stations)
      from there i may be able to limit the results to those in a particular direction or even do it automatically via road runners gps heading (NE S W etc)
      just with some rough math here to do the batch downloads (if possible) 200 zip codes yields only a 35 miles radius id grab every third or fourth zip because of this but
      200 stored htmls @ 5k each = 1 MB just for a half hours drive
      so batch may not be worth it also the bigger the radius get the more uneeded stations get loaded
      please chime in with any thoughts thanks
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    NY
    thoughts comments sugestions?
    for those that did download it did it hae any dependancy issues
    missing ocx/ dlls?
    crashing etc
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Apr 2006
    Washington, DC
    Quote Originally Posted by lostreception
    missing ocx/ dlls?
    crashing etc
    I tried running it but I'm having to head to work now so I'll have to continue in the morning, but when I click on SEARCH it opens windows installer and tries to locate and install DAO.MSI . A quick search on google gave me this site "http://www.domainpunch.com/support/articles/dao360.php" but I don't have the time to try it out yet... I'll get back to you about what I figure out... Later.
    NY
    ok can any vb programmers chime in and guide me in the right direction for including the nessisarry dlls etc
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. RR lower volume for GPS Directions
    By UM_Fan in forum Road Runner
    Last Post: 02-28-2006, 10:46 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  4. RR forgets GPS port!!!
    By eduardovdr in forum Road Runner
    Last Post: 07-17-2005, 05:11 PM
  5. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
